Author Subject: Battery died afer massive traffic jam!
slicksh$t
The Alliban
Hi guys,
I was in Greenwich on Saturday and the traffic was horrific and I was stopping and starting in traffic for about 3 hours. At points I switched the engine off as I was standing still for 10 minutes at a time. Eventually the car would not start when I turned the ignition on and the car wasn't even turning over and the plipper would not even lock the car and alarm it up. The only way I could get the car started was to get someone to connect a charger to the battery, which allowed me to then start the car. After that, the car ran fine. The next day though I had the same problem from cold and it wouldn't start.
Do I need a new battery?
Is the alternator gone do you think?
Any help / ideas would be much appreciated.
Thanks again,
Karl Smile
Woo Hoo. Back in a 306 Rallye and Lovin' it!
Posted 4th Mar 2009 at 02:34
Is the alternator light on?
Also, chack the battery Voltage when running and when standing. It should be iver 14.5V when running and over 12.3V when standing.
Posted 4th Mar 2009 at 03:52
smegal
I'm saying its a knackard battery.
Ex SC-6
Now in a Megane R26
Posted 4th Mar 2009 at 04:20
dr-evil
Could be the battery terminals - had this on both the rallye and one of the dt's - because the battery was free to move it'd wiggle the terminals off.
Cad Monkey will work for chocolate biscuits....I'm not kidding
Posted 4th Mar 2009 at 05:18
westy306
Does the Ignition (battery symbol) illuminate when you bring the ignition switch on to position 2 before you start?
It's best to measure battery voltage under load; so get someone to crank the engine while you measure. A good battery shouldn't dip much below 9V when cranking.
Multiple starts while you've been idling for hours is just draining your battery. To get any kind of charge back into the battery the engine needs some revs, as idling is just trickle charging the battery.
It might be possible to trickle charge <2Amps the battery back into life using a mains charger, but your success depends on how long it has sat in a discharged state.
If in doubt replace.
Posted 6th Mar 2009 at 00:26
slicksh$t
The Alliban
Just dont even get any battery signal on position 2 unfortunately. Getting a new battery in the morning Smile
Posted 7th Mar 2009 at 04:26
mik
Off topic and epic thread bump I know, but great avatar.
Cherry Rallye SOLD
Posted 1st Oct 2012 at 20:41
rich306
Hahahahah You nutcase!!Big grin
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 2nd Oct 2012 at 08:44
It was worth the bump just for the view. Wink
I would ask the OP if a new battery solved it but he's unlikely to answer as he's not a paid up member. Doh
Posted 2nd Oct 2012 at 14:38
rich306
That sucks...
- Top Tip!!!
Posted 2nd Oct 2012 at 19:37
