displaying posts 126 to 130 of 130
Pages (6): first .. 4 5 [6]
Author Subject: Max lift at TDC?
Post #126
standard cams I'm guessing? if so you may be ok.
a decent quality MLS gasket should be just fine, i believe that's all the 405 T16 engine ran at 1.2 bar, they weren't known for gasket issues at all.
radial checking of valve clearance is a bit tricky with the valves inclined and a small cutout, usual trick is to dot punch the piston gently at tdc down the valve guide.
Posted 7th Jun 2017 at 14:19
Post #127
Yeah standard cams.
Would putting a touch of micrometer blue on the outer radius of the valve then pushing it down until it hits a piston at TDC then removing the head be another way of checking radial clearance?
Ive still got the old gasket so could mount an inlet and exhaust valve in their guides, sit the head on the old gasket and nip it down with four head bolts then wind a piston to TDC and do that check relatively quickly and easily.
Posted 7th Jun 2017 at 14:25
Post #128
that may work yes, no experience of using that kind of stuff myself so not sure of it!
Posted 7th Jun 2017 at 14:59
Post #129
Just measured exhaust valve clearance at TDC, it is 2.1mm. Is that cutting it too fine or will I get away with that?
Posted 7th Jun 2017 at 18:40
Post #130
Bump
Posted 9th Apr 2019 at 22:05
