Author Subject: Oil pressure guage
xsibloke
had a quick look through but couldnt find anything the problem i have is iam getting no reading at all whilst the car is running. when you first put the key in it sort of flickers up abit but as soon as started drops off, could this be a guage fault or maybe a sensor in the engine? where does it pick up the readings? oh and its a xsi
Posted 26th Jul 2009 at 04:47
paul_13
Could be a fault with the sensor/dial.
Hopefully your bottom end isn't about to seize LOL
AFAIK the sensor is below the far left hand intake port. Should be a grey sensor(could be wrong)
Give the plug a wiggle its french!
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 26th Jul 2009 at 05:01
xsibloke
I hopeing not !!! No
it seems as thou it loses power to the guage when its started as it lights up wen u key on, but as soon as it starts the guage light goes off? mind i dont know if thats supposed to happenLOL
Posted 26th Jul 2009 at 18:41
u5d90
mine does the same?
i get a reading when i turn the car on - always reads full - then just drops to the off position when the engines running?
Posted 17th Nov 2009 at 04:59
white cylinder in the block is the culprit
you should get a level reading when you turn the igniton and it should be showing pressure when running
Posted 17th Nov 2009 at 05:20
u5d90
is this a major problem/big job to fix?
is it a common fault, and is the sensor expensive to replace?
Posted 17th Nov 2009 at 05:44
you can see where it is on my engine there, it'll be similar position on your engine i'd have thought. i haven't removed mine tbh but it can't be hard
i haven't personally had issues with the sensor going though
Posted 17th Nov 2009 at 21:10
ballys16
Not hard to remove at all - not breaking the plastic around it is Smile
As for the readings: while it was OK on the XSi, the same sensor in the S16 is somewhat erratic.
(cable is different, could be the problem....)
XSi 8V -> S16
Posted 18th Nov 2009 at 01:01
miles
16v XSi's don;t have a oil pressure guage only the 8v ones did along with all phase 2 on GTi'6 which had the temp instead, XSi's just had the oil level
www.pugracing.com
Posted 18th Nov 2009 at 06:14
