Author Subject: cleaning map sensor on s16
paky
Is it posible to clean it on s16,
map is in ecu box Roll eyes
www.paky-stunt.com
Posted 6th Sep 2009 at 02:24
Welly Forum Admin
Yeah a bit of fairy liquid and a microfibre
Vrs power!!
Posted 6th Sep 2009 at 02:33
abergavenny_306gti6
i just used a foam bud find you get some oil build up in it
Posted 6th Sep 2009 at 02:48
paky
does anyone know what is this thing
its going from map sensor in ECU to inlet manifold Whistle car is s16
www.paky-stunt.com
Posted 6th Sep 2009 at 15:46
dan_s16
According to Peugeot it a: PAD CAPACITY 1957 46
I believe it's like a little buffer to smooth out the vacuum being sent to the Map sensor but I could be completely wrong.
I've been to the local Bosch dealers to see if I can get a replacement MAP sensor and they phoned Bosch up but they weren't being very help full and said it's a dealer only part (so new ecu basically
Posted 6th Sep 2009 at 20:06
paky
im asking becouse i dont have that thing on my car
and when i let it in gear on idle it is not smoth it should be. Bit speed up and bit speed down Dry
iw tryed to pu new stepper motor but same thing
Now i think its map sensor or its becouse i dont have that thing Sad
www.paky-stunt.com
Posted 6th Sep 2009 at 20:22
ive heard its to smooth the flow out too, think 'swirl pot for air'
i have about 5 of them in the garage from when i had map issues. eventually i replaced the ECU with another from the same year car / spec and it was fine. there is no 'sensor' as such but it picks up the reading from the outlet that is on the ecu if you pull it apart. if you have map issues i think you need to try another ecu or have it repaired
Posted 6th Sep 2009 at 22:08
dan_s16
There is a map sensor but its soldered to the circuit board, I was going to desolder it then get a replacement unit from another car (i'm hoping the gti 6 one is electrically the same and solder some wires to the circuit board and then fit the map sensor out side of the ecu. whos ever idea it was to put the map sensor inside the ecu and not do a relacement wants shooting.
Posted 7th Sep 2009 at 01:01
doubt its the map sensor causing the idle issues, more likely to be the idle valve.
Posted 7th Sep 2009 at 19:40
abergavenny_306gti6
he has already replaced that though mei . . . how about engine temp sensor that could be causing it . . .
Posted 7th Sep 2009 at 19:42
paky
iw tryed to put new ecu from my friend and car works perfect, looks like map sensor faulty and i cant clean it becouse it is in ecu box Unsure
www.paky-stunt.com
Posted 8th Sep 2009 at 00:18
ballys16
Try ebay - I got one from Germany (brand new) for ~5 euros... also, you can try http://www.syntech.hu - Gabor Arvay (arvayg@syntech.hu) is someone I know who actually did mention swapping the MAP for another one.
XSi 8V -> S16
Posted 8th Nov 2009 at 02:25
ballys16
As the others said - but it being there does nothing, as I did not have it when I swapped the engine and could not notice _any_ change when I put one in.
XSi 8V -> S16
Posted 8th Nov 2009 at 03:04
mr swampy s16
**BAD SELLER**
Nice pic of my engine bay there.
Posted 8th Nov 2009 at 02:57
