Author Subject: oil temp/pressure
pugheaven
Hi was just wondering what the min, ideal and max oil tems and pressures are.
For example if you had an oil cooler with a stat what would be the ideal open close temps for the stat?
Thanks
Ollie
Posted 20th Sep 2009 at 02:56
Most stats you will buy with an oil cooler kit will open and close at 80C...Yes
You will be fine with this temperature.
The ideal pressure is around 4 bar when warm.
Hope this helps,
Stan.
Posted 20th Sep 2009 at 20:22
pugheaven
yes that helps thanks mate. The reason i ask is iv found a oil filter relocation kit including a cooler. Iv posted it in the general section. I cant see how you can add a stat to the kit. Thanks
Posted 20th Sep 2009 at 20:49
You can either get an inline stat or one which is built into a sandwich plate. Yes
Stan.
Posted 20th Sep 2009 at 21:15
pugheaven
but both will stop the oil to the filter and cooler not just the cooler.
Posted 20th Sep 2009 at 21:20
