Author Subject: Rattle/knock when revving
jimmerpug
A friends 6 starts and idles fine but when blippimg the throttle it starts to rattle from the top end quite badly. All compression figures are 190 plus on all cylinders. Plugs were all tight and look fine. The engine had been sat up for a while before being installed from another car. New filter and 10/40 semi synthetic oil was put in. Could it be a stuck tappet? or am i just putting off the inevitable bent valve conclusion?
Any help much appreciated
Posted 26th Sep 2009 at 23:08
oecken
dont know about the tappets, but check the top engine mount, prone to cracking badley, which makes a knock noise when revving changing gear etc... worth a look for free Thumbs up
also search for top engine mount, some of the threads have pic to explain better.
Posted 26th Sep 2009 at 23:13
jimmerpug
I dont think its the engine mount its deffinatly top end from head/cam area
Posted 26th Sep 2009 at 23:15
sounds like it could be bottom end bud sometimes sounds like its coming from the top Sad Only thing to do is whip the head off an have a look Angry
Posted 26th Sep 2009 at 23:19
