Author Subject: Lower engine mount....Info needed please :)
lwgti-6
Afternoon!..
I.m planning to change the bottom engine mount today, i've read through the FAQ on here and im still a little unsure what to do as it says something about hacksawing the original bush? I've also heard about the new mount needs to be "pressed in" using a press? But it mentions nothing about that on the FAQ? The new mount is a baker group N..
Any help would be muchly appreciated.
I just dont want to start the job, get the original bush out to find i cant get the new one in.
Cheers Whistle
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 27th Sep 2009 at 17:03
monkeyman
You need to take the bottom mount holder plate off, which includes the drivers side drive shaft, so have a bottle of gearbox oil to refill.
You will need a huge press to fit a hard rubber mount in, find some where that will do this job before you start undoing things.
The polyurethane bushes come in two halves and are easier to fit but less durable.
Forum Search Clicky
Posted 27th Sep 2009 at 18:25
lwgti-6
oh right, cant i just offer the bush upto the hole and knock it in with a hammer and socket?
EX Bianca 6 owner,
Posted 27th Sep 2009 at 22:06
mechanical_repairs
No that wont work as the bush is a bugger to get started in the mount itself.
Carl
Posted 27th Sep 2009 at 22:11
lwgti-6
ok guys, cheers....
New aux belt = fail (wrong size belt)
Engine mounts = Fail Sad
Best put her back together...humph
EX Bianca 6 owner,
Posted 27th Sep 2009 at 22:25
oecken
Change lower engine mount and gearbox today Razz
Posted 27th Sep 2009 at 23:06
jonnie205
i just press the new one in and push the old one out at the same time, no need for cutting or burning the rubber out that way
Posted 28th Sep 2009 at 02:15
monkeyman
lwgti-6 wrote:
ok guys, cheers....
At least you asked on here, another hour of taking stuff apart could have left you car-less for the week.
Forum Search Clicky
Posted 28th Sep 2009 at 15:57
i am embarking on this task this week. i anticipate anger, rage and swearing. good job i have a reliable german masterpiece to count on when my french heap leaves me stranded Razz
i'll be finding somewhere with a press this week and taking the whole lot to them to deal with
Posted 28th Sep 2009 at 16:10
lwgti-6
Does anyone have a guide on how to take the assembly off with the mount inside? A freind of mine has a huge press i can use but i'm just wondering how it comes off. Me and driveshafts dont seem to meet eye to eye..
EX Bianca 6 owner,
Posted 2nd Oct 2009 at 01:18
oecken
this maybe one of the ones you looked at, i didnt hacksaw the mount though.
this looks like it should have what you need i took the drivers side driveshaft out as its easier iirc, it has an optional step for lower engine mount Thumbs up
Driveshaft / mount
and there is this one i used last week, but i had group N's to fit, as the one shown is powerflex and comes in 2 halves, mine was slightly easier as i got miles to press it into another housing he had.
Lower Mount
Posted 2nd Oct 2009 at 01:41
removed my engine at weekend and got all the lower mount off to replace with my solid one. i assume that the metal ring is the outside of the existing mount and this is to come out? this isn't a part of the mount housing itself is it?
Posted 5th Oct 2009 at 17:18
oecken
Which bit you reffering to ricky?
thats a pic of the old mount and the new group N, but i got mine pressed in before it was sent...
Posted 5th Oct 2009 at 18:18
i mean, the actual standard mount has a metal ring on the outer edge, like a casing, and it's not just rubber - looks to be that way anyway. i blowtorched mine out but forgot about the ring, so it's within the cradle now so needs pressing out. no problem really..
Posted 5th Oct 2009 at 18:58
I normally just tap the edge of them in with a chisel until it folds up and drops out.
Posted 5th Oct 2009 at 18:59
i kinda, erm, savaged mine :whitle
Posted 5th Oct 2009 at 19:14
