Author Subject: Removing brake flexi lines
kezman7
Im swapping my brakes for some bigger ones but i need to swap them myself. I have bled brakes before but i havnt delt with the hoses. Whats the best way to remove the flexi hoses from the car side (still connected to caliper) without damaging them as ill need to reuse them.
Can heat then C02 be used to crack any seized lines loose like with seized nuts? Also aided with lots of WD40 or simular?
Thanks
Posted 6th Oct 2009 at 04:53
mr swampy s16
**BAD SELLER**
Get proper brake spanners and take your time.
Its realy easy to damage the unions.
Posted 6th Oct 2009 at 12:36
kezman7
I have had alook on demon tweeks and theres a choice of many difference sizes, What size will i need for the Gti6 lines and also the other brakes are from a different peugeot but not sure which
Posted 6th Oct 2009 at 17:57
11mm brake pipe spanner, 17mm and 13mm maybe 14 sometimes for the rest.
Posted 6th Oct 2009 at 18:10
mr swampy s16
**BAD SELLER**
Halfords do the spanners for the pipes
Posted 6th Oct 2009 at 19:20
