Author Subject: No start
lexus
Engine wont start,
i was driving along 30ish in a 40mph, engine went to die(revs droped) then got to say 5rpm and picked back up to normal ish tick over at 30, then 20 yards down the road revs droped but never pickewd bk up so, i droped a gear revs picked up then died so i cruised to a hault, had a quick luck but was getting on and was very dark so pushed it up the road to a safe place ect, its an ecosse car so they had removed the toe'in eye, so left it over nite, come back in morning to get her home, and got it home , but still wouldnt start, it sounds like it wants to start but no spark in the engine so my 1st guesses were coilpack, spark plugs or cam belt???i have changed coilpack with 1 i had lyin about, i changed spark plugs 2weeks ago(as well as oil filter and oil) they look fine, and cam belt is fine, any idears???im lost HELP!!!!!!!!!Sad
Posted 12th Oct 2009 at 23:06
musclebeach
And still no spark? Sounds like a fuelling issue to me, are your getting good fuel pressure at the rail?
VW Golf GT TDI 115, 100k nooooooooooooooooooooo!
Posted 13th Oct 2009 at 00:34
chris167
is the battery connections ok? is the pump priming?
There are currently 1 people online
Most ever was 173 on Sunday 9th Nov 2008 at 8:04pm
Registered Users: chris167
Posted 13th Oct 2009 at 00:37
lexus
pump primes and how can i check good presure at fuel rail???
have disconnected battery and re connected when it went no luck
crank sensor???or fuse???
Posted 13th Oct 2009 at 01:25
chris167
prime it with the fuel rail/ injectors out. if your eyes are burning then chances are its sprayed out all over your face, into your eyes, and you cant see. chances are after your eye sight returns you will realise you have good pressure!
Posted 13th Oct 2009 at 01:58
lexus
theres compression when turning over the car out off the exhaust, so should i try rail next???
Posted 13th Oct 2009 at 03:25
chris167
fuel filter clogged?
Posted 13th Oct 2009 at 03:28
jimmyrallye
emergancy fuel cut of switch ?
Posted 13th Oct 2009 at 03:30
lexus
were is the fuel cut switch?looked the nite it went but was too dark and forgot to look since, and would the fuel filter just randomly cut out??
Posted 13th Oct 2009 at 04:05
lotek
fuel shuoff is in engine bay , top right corner.
red square device with circle imprint, press the middle of it .
also try replacing fuel filter.
may be worth looking at fuel lines by the cambelt where they join the plastc pipes, see if they have come off , although you would smell it by now
Posted 13th Oct 2009 at 06:13
musclebeach
Rule things out before replacing fuel rails etc.
1.Have you definately got a good spark on all four spark plugs?
2. Have you got fuel delivered to the fuel rail? - if so at what pressure? - you need a guage.
3. Before replacing the crank sensor get the dtc's read on a diagnostic machine - if there are any! If there are record them and clear them and then try and start it again, this rules out going off old codes if any are stored in the ecu memory.
4. Have you checked fuses? If not..Why not?
5. It is possible of a cambelt failure, take off the top cover and turn the engine over by hand and look at the belt- if unsure put a line on it with pen and check the belt when its come all the way round.
Hope this helps
Posted 13th Oct 2009 at 23:54
