Author Subject: ITB Fuel Pressure Reg
itchytrigafinga
Hi,
Searched the forum about these FSE boost valves. Found a lot of info on running these with standard setup, ie the concensus is its poinltess.
I have an ITB kit but it doesnt have a fuel pressure regulator on it, presuming the standard one will have to come off when the new manifold and bodies are fitted, would the FSE boot valve work well?
Will
Posted 14th Oct 2009 at 22:54
pugheaven
I need to know that as im fitting mine soon
Posted 15th Oct 2009 at 03:28
jenvey and colin satchel, as well as weber IIRC do a housing to accept the standard top hat style FPR.
Posted 15th Oct 2009 at 05:22
itchytrigafinga
Got this reply from Jenvey when i emailed them about it:
"The RH01 adapter we do is 39gbp"
RH01 = Jenvey Part Number.
This is for the housing for the standard fuel pressure regulator.
Posted 16th Oct 2009 at 22:59
mark-house
Ive asked this before and have been told that fse are shit. the standard one will do the job fine. the high boost guys use the standard one on the supercharge set up so i think they should be fine for ITB's. also have been told that if 3 bar isnt enough that VW do one that is rated at 4 bar and fits just like the standard.
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 16th Oct 2009 at 23:23
sandy
Please, for the love of god, stick with the OE type capsule regs! The single most common cause I see of maps going off, is a dodgy FSE or similar adjustable reg. They just aren't stable enough over time and temperature.
Posted 27th Oct 2009 at 00:52
pugheaven
Will a standard 3 bar do for 285 cams and itbs or will the 4 bar be needed.
Thanks
Ollie
Posted 27th Oct 2009 at 00:55
3 bar will be fine.
Posted 27th Oct 2009 at 00:56
pugheaven
k thanks.
Posted 27th Oct 2009 at 00:57
itchytrigafinga
Update on this, got the adapter from Jenvey, Part no: RH01.
Im guessing its correct?
Posted 5th Dec 2009 at 17:56
chris with a pug
I know jim runs an in line one
Posted 5th Dec 2009 at 18:54
chris with a pug
this one
Posted 5th Dec 2009 at 19:18
itchytrigafinga
Yeah, mine is just an adapter so that you can use the standard top hat style fuel pressure reg instead of buying a completly new fuel pressure reg.
Posted 5th Dec 2009 at 19:25
yeh, looks fine, resizing the image would be nice though so I don't have to scroll sideways to see it LOL
Posted 7th Dec 2009 at 22:06
itchytrigafinga
Cool, will keep that in mind next time I upload a pic to photobucket.
I did wonder when I was uploading it whether linking a picture of such magnitude would crash the forum Whistle
Posted 7th Dec 2009 at 23:47
RallyeP6
Just found this after doing a search, it exactly what i have been experiencing with my FSE after a less than a year of use.
I have left the pressure guage on there as it varies so much. One day it is 42.5, another day its gone up to 50, i re adjust it down to 42.5 and hey presto, another day its sitting at 30Psi.
Saw the adapter that Jenvey do for the original capsule, will probably go for one of those.
Posted 21st Sep 2015 at 17:06
satchell have made some, cheaper than jenvey iirc.
Posted 21st Sep 2015 at 18:02
RallyeP6
Just checking there website, can't find it, may have to email them.
Posted 21st Sep 2015 at 19:45
