displaying posts 26 to 50 of 81
Pages (4): 1 [2] 3 .. last
Author Subject: 406 Brembos and Xantia Disc help
bellcp306td
lotek
Whats going on with the pipes?
Where did the road go!
Posted 15th Oct 2009 at 17:16
lotek
i need those 100mm l bend pipes so i can use my existing braided brake hoses.
Posted 15th Oct 2009 at 17:38
bellcp306td
ok sorry can't help, I just got new Braded lines made.
Posted 15th Oct 2009 at 17:46
[l\'e$kro]
I suggest you use a set of 283x26 discs from a gti-6 or a 307 Hdi, they are centered with the calipers and won't squeal as much as the Xantia 288x28 ones which have the wrong ofset
Nicolas
205 gti xu10j4rs
ms2 extra sequential
Posted 20th Oct 2009 at 19:43
rallyestyle
I have some mate Whistle
They are used but you can have them Thumbs up
PM me if you want me to get them over to you Ninja
Just Drive It
Posted 20th Oct 2009 at 19:48
lotek
Nicolas
so i can just use my existing discs?? wont they be too small for the pad??
Posted 20th Oct 2009 at 19:57
pugheaven
Not sure but iirc if using standard discs the pistons can reach maximum travel and maybe pop out if your pads are low. Think the 406 brembos require 28mm width discs as min. Not 100% sure
Posted 20th Oct 2009 at 20:20
lotek
ok xantia ones it is then cheers. will get some cheap jobbies and spend some more on pads.
cheers
Posted 20th Oct 2009 at 20:27
pugheaven
you will never get rid of the noise unless you go to 330mm bell and rotors!
I couldnt stand the noise so i sold my set and got ash's 310mm kit with 225 brembos.
no noise and much better calipers.
Posted 20th Oct 2009 at 21:01
Post #35
don't have to have 330mm, could go for a stock diameter 305mm belled disc and rotor.
Posted 20th Oct 2009 at 21:54
pugheaven
Post #36
True.
I only said 330 as thats what ash's kits used.
Posted 21st Oct 2009 at 00:16
bellcp306td
Post #37
There is no noise free solution that i know of. i used to run them with a 307 110 Hdi disk. They are better then the 6 brakes but not much better.
Posted 21st Oct 2009 at 18:04
anderoo
Post #38
Carl (mech_repairs) can make these up for you. Smile
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 21st Oct 2009 at 18:51
Post #39
phillipm wrote:
Backing shims on the pads, lightly grooved/2 piece/wavy discs, chamfer pads, damped sliders...
Stop teasing me you bas**rd, I want them now! Angry LOL
Posted 21st Oct 2009 at 19:43
Post #40
LOL
So do I! I'm getting bored with no milling machine to play with LOL
Posted 21st Oct 2009 at 19:48
Post #41
Can't you make them with a file and a drill? Like a propper engineer could Whistle Razz LOL
Posted 21st Oct 2009 at 19:51
Post #42
LOL
Posted 21st Oct 2009 at 19:52
tyerz
Post #43
jus a thought on this one cuz im planning on fitting brembos but now not so sure but would a 406 V6 coupe hub conversion not be an do-able and sort the problem out??
Posted 18th Nov 2009 at 19:48
anderoo
Post #44
If it is I'm not sure it'd sort it out anyway, They still squeal on the 406's and the Fiat Coupe's they were fitted to as standard.
Pics of my 6
Posted 18th Nov 2009 at 20:08
tyerz
Post #45
ahh right, hmmmmm not sure if to put em on or not now
Posted 18th Nov 2009 at 23:40
vts_gav
Post #46
latter xsara vts's use the 26nn thick discs ideal for brembo calipers
Posted 19th Nov 2009 at 01:41
lotek
Post #47
im still trying to figure out what discs we can use for the brembos other than the xantia ones
gti6 discs sit offset,
gti 180 discs fit ok?
406 coupe discs wrong offset?
xsara hdi estate 2001 , Seem ideal? 283x26
307 lx 283x23 usable?
what other cars discs are an option? the xantias are OVERLY heavy.
why cant the 406 coupe discs be used?
Posted 12th Dec 2009 at 21:35
Post #48
The late Xsara disc could be a good option. Someone else has mentioned them on here before and yes the Xantia ones do seem pretty heavy, however not a million miles off the normal GTi6 discs.
Was going to weigh everything when I changed over.
Posted 12th Dec 2009 at 22:58
Post #49
following this with a little interest, I'm still on 266x20.5mm LOL
my discs apparently weigh 4.7 kg,
the gti6 283 x 22mm disc is 5.95kg,
the C5 discs commonly used is the same as the Late Xsara discs, 6.74kg.
283 x 26, 34mm height.
one thing I can't remember about the 405/6 hub is whether the radius of the lugs are the same as the other cars (106/205/206/309/306/307)
what I do know is that the offset to the hub is a lot lower hence why its not possible to use the discs on a 306 (and why BBS made the special Coupe wheels) a 406 V6 disc is;
305 x 28mm, 28mm height, 7.9 KG Crazy
if the caliper sits at the same radius, a 307 2.0 HDI 135 disc looks to be exactly the right spec to fit;
302 x 26 - 34.1mm height (same height as the C5 discs, but a lot larger diameter, this may help against squeal.)
they weigh 8.42 kg though Shock
Posted 12th Dec 2009 at 23:25
Post #50
How much do the Xantia ones weigh?
And what height/size etc are they?
Posted 12th Dec 2009 at 23:37
