Author Subject: brake squeal on passenger front
topshot_2k
Changed all my pads 2 months ago for mintex 1144's copperslip on the backs etc
Now the passengers side front squeals everytime i brake when cold/slightly warm and i seem to get the same squeal when i turn the wheel even without applying the brakesCrazy but its only from the front passenger side and only at slow speed?
any ideas?
Owner of a Nile Phase 2 GTI-6 & Impreza WRX Smile.
Posted 20th Oct 2009 at 02:04
tabbbster
Mine is doing this aswell, But both fronts. Like you only when cold or a bit warm and at low speed. Never did it with the first set of M1144's I had with XDG maxtorq disks. But its doing it loads with the M1144's and XDG black diamond disks. I am using the rubber backing stickers but no copper slip as I find it just atracts dirt.
What disks are you using?
Could just be this batch of pads. Dunno Mine have been fitted for 3 months approx.
My Rallye was built on thursday 7th January 1999 according to the cosmic code generator.
My Cyclone refurb
Posted 20th Oct 2009 at 02:17
topshot_2k
im using standard disks, i used the backing stickers and copper slip but it still does it.
I just read that someone had a problem with them coming of the backing plates could this be an issue still with the 1144's?
Posted 20th Oct 2009 at 02:33
tabbbster
The last set I had was fine, I think they would make a lot more noise if this was the case.
My Cyclone refurb
Posted 20th Oct 2009 at 02:42
