Author Subject: Estate Rear Beam
maybe
Evening all, Slightly of topic from the Gti 6's but I currently have a 306 Hdi Estate but notice when loaded the rear suspension is very soft.
Any idea's what I can change to increase the payload without making it look like a monster truck?
Cheers Ed
Posted 22nd Oct 2009 at 02:51
torsion bars from a higher spec estate or a xsara vts if they are not 21mm.
Posted 22nd Oct 2009 at 03:39
c_j_m
If its a HDi you'll have 21mm bars and a 24mm ARB so better than a GTi.
Uprated torsion bars are around
Posted 26th Oct 2009 at 23:16
not always, I checked the VIN of a HDI for someone earlier today and it came back as 20mm.
Posted 27th Oct 2009 at 01:24
c_j_m
Strange.
Posted 27th Oct 2009 at 08:04
iplay
Easy route is to buy 2 new OEM dampers.
Posted 27th Oct 2009 at 17:14
monkeyman
Raise the rear beam a little?
if you have a micrometer make sure you have estate rear tortion bars fitted, not standard 306 ones.
Forum Search Clicky
Posted 27th Oct 2009 at 17:24
d_p
guys, how about beam from xsara vts 1.8 16v R reg. is it have thicker torsion bars ?
1998 GTi 6 - Black > Sold
Posted 30th Oct 2009 at 01:56
nope
Posted 30th Oct 2009 at 02:27
maybe
Cheers for you input guy's, I'll take away some of these comments and do some research.
It is a Hdi Meridian Estate.
Regards raising the rear beam, I didn't want a monster truck when unloaded.
Posted 30th Oct 2009 at 03:49
c_j_m
From what I've seen most estates sit stupidly low at the back anyway.
Measure the sills front and back, the rear should be around 15mm higher
Posted 1st Nov 2009 at 04:32
birk
21mm bars are black, 20mm ones are red iirc.
The high spec estates came with 21mm bars and most of the late ones, but you know what pug are like, could whack any old beam on, could have been a friday you know LOL
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 1st Nov 2009 at 04:46
Stick some Polyurethane foam bumpstops on the damper shafts, the progressive type, it'll lift the spring rate when fully loaded then.
Posted 1st Nov 2009 at 07:32
