Author Subject: 3.0 v6 conversion driving me mad
boz_v6
does anybody have any decent detail on the 306 3.0 v6 conversion i have the d8 engine and a good garage to do the work but because they are vw/audi specialists theve never done one help please
Posted 30th Oct 2009 at 01:15
You are getting a garage to do it?! Bloody hell...
Have a good search and you should find a few things.
Posted 30th Oct 2009 at 01:34
boz_v6
i've looked everywhere but cnt get any solid detail ive got a rough idea of parts that need altering eg, downpipe,engine mounts,driveshafts but havent a clew on the loom or gear linkage
Posted 30th Oct 2009 at 01:41
Gear linkage you just use the 406 cable system.
Driveshafts need to be created.
Answer from welshpug gained from a search:
yes it will fit, needs 2 custom mounts, gearbox one bolts straight on though.
shortened 406 shafts, modified subframe, radiator to suit, fit the 406 cable shift system (easy joCool
sort the wiring, which is straightforward on the 194 bhp engine, PITA on the 210 engine as you need an aftermarket ECU.
Posted 30th Oct 2009 at 01:51
VW VR6 rad.
Posted 30th Oct 2009 at 01:55
boz_v6
ideal that makes things alot clearer sounds easy when you put it that way cheers
Posted 30th Oct 2009 at 01:59
steve954
lee306v6 has the conversion in his rallye could pm him for some info.
stevie
09 308 gt140 cc
03 octavia vrs
IF IT AIN'T BROKE, IT AIN'T A GTI6
Posted 30th Oct 2009 at 02:04
boz_v6
is that the rad off a golf vr6 or are they al the same
Posted 30th Oct 2009 at 02:19
I have seen that Hilgie changed to a 1.6 golf rad as they have a bleed point in them which the VR6 dont, otherwise they are the same size apparently.
Posted 30th Oct 2009 at 02:22
boz_v6
there is a mk3 golf vr6 rad on ebay will that do the job
Posted 30th Oct 2009 at 02:26
