Author Subject: P1 XSi / S16 front wiper relay
ballys16
Hello there,
I have in fact searched before posting this question but there is no such info about.
Which is the front wiper relay on a Phase1 XSi / S16? And its a LHD ...
XSi 8V -> S16
Posted 16th Nov 2009 at 01:54
big tall baby blue one (on a rhd)
Posted 16th Nov 2009 at 03:34
ballys16
Thank you!
I will post a pic of the box tomorrow as I have no blue relay - probably changed by the previous for some aftermarket piece...
XSi 8V -> S16
Posted 16th Nov 2009 at 04:08
dan_s16
It's not with the other relays, it's behind the fuse box (as in you need to unclip it and move it to the side and reach into the dash) with all the wiring IIRC.
Posted 16th Nov 2009 at 06:36
ballys16
OK, so call me thick.
I have removed the fusebox (which i cannot put back now) and there are no relays to be seen.
How many relays are there that are visible having the cover removed? I have like 8... 4 above the fusebox, 1 to its right and three more below the steering column.
I played about in the opening behind the box just to feel for any relays that I might not see, but no... unless they are somewhere near the bulkhead?
At least I was able to put the fusebox back in its place....
XSi 8V -> S16
Posted 18th Nov 2009 at 01:07
ballys16
Thank you everyone, finally found it and replaced it.
Its not that easy to get to Sad
BTW, its the same relay as the rear one, thankfully.
I had two types, one a straight cube type and another that is smaller and is more slanted - this is the one that fits, the other you can fit but the whole thing wont go back in place.
XSi 8V -> S16
Posted 7th Dec 2009 at 20:38
