Author Subject: remove outer cv from shaft?
bobdylan_55
anybody know how the outer cv joints remove from the splines on the main part of the shaft? cheers
309 GTi6-T
Posted 20th Nov 2009 at 03:06
gti6-ginge
Hi think there is a C clip on the end of the tripod joint that you have to removed then tap the main body of the to removed. becareful not to hit the roller bearings. Thats how i got them off the toyota shafts at should be the same on all i think maybe different on pugs
MY CAR WAS BUILT ON 17/03/2000 THATS A FRIDAY OH NO
Posted 20th Nov 2009 at 03:14
bobdylan_55
im after the outer joint, ie in the hub end.
309 GTi6-T
Posted 20th Nov 2009 at 03:25
mechanical_repairs
All you need to do is give it a swift blow with a copper hammer.
Carl
bobdylan_55
for the hub end? not the spider end, the other end.
309 GTi6-T
Posted 20th Nov 2009 at 03:49
pulled mine apart by mistake, the jubilee or pug clip just came off with ease and all the roller bearings fell out and i still have half of it stuck in the hub which simply won't come out! although i am doing it without feet on the brake as they're unbled
Posted 20th Nov 2009 at 03:50
bobdylan_55
i wasnt aware of any roller bearings in the hub end? i thought they were just ball bearings.
309 GTi6-T
Posted 20th Nov 2009 at 03:52
LOL
I did that with the brava the other day, wasn't fun hunting for needle rollers in the rain.
fugs
I'm actually doing this myself at the moment! Need to change a cv boot.
So a swift bang of a mallet will do! But what roller bearing are you people on about? Surely there is no rollere bearing in the cv joint?
Can the inner crive pop out of place easily?
Posted 6th Feb 2010 at 22:41
theyre all getting confused there, there are only balls in the outer joint.
a swift thump to the spider will drive the joint off, there is a round wire clip in a groove inside the joint that stops it from simply sliding off.
you get a new clip in a GKN boot kit, but usually its fine to re-use the old one.
the inner tripod joint does come apart fairly easily from its cup so beware of that if you do it in situ.
Posted 6th Feb 2010 at 23:07
