Author Subject: Flywheel skimming
cabbymeg
Hi all,
How much should I have taken off my flywheel when I have it skimmed?
Thanks,
Posted 26th Nov 2009 at 18:42
depends how much like a pringle it is.
Posted 26th Nov 2009 at 18:51
As little as possible to clean it up, if it needs a fair chunk off, then the relief will want machining too to keep the preload the same on the pressure plate.
Posted 26th Nov 2009 at 18:52
cabbymeg
The relief? What's that?
Posted 26th Nov 2009 at 18:56
The bit the clutch cover bolts to.
Posted 26th Nov 2009 at 19:02
chris with a pug
I had to have mine skimmed a few years back, the clutch went again scoring the fly wheel and they couldnt skim it again as there is only so much you can take off.
Posted 27th Nov 2009 at 00:39
andrewrallye
To clean up the clutch face, make sure that they are going to surface grind it as opposed to turning it on a lathe. In use you can get very hard spots on the flywheel, especially if the clutch is slipped a lot. When trying to skim the face on a lathe the tool jumps over the high spots, so you don't realy achieve much. This only applies to the face, a lathe will be ok for the rest of the work, lightening etc.
E reg 205GTI non sunroof maybe for sale m.o.t'd ideal rally, trackday car, also have 6 engine and box available
Posted 27th Nov 2009 at 14:58
