Author Subject: Obtaining camber?
r*byb
Hey guys i want to run 2 - 3 degree's camber, i see the compbrake ones on ebay only go to two degrees.
Are there any other options for the front ? linky please.
And whats the rear end options ?
Cheeers
Team Low Compression
Posted 15th Dec 2009 at 20:12
modified strut casings or hub carriers for the front, modified trailing arms on the rear.
what gives you the need for that much camber? running full slicks?
Posted 15th Dec 2009 at 20:22
r*byb
No running semi slicks but will be very light.
Is my best option the comp brake top mounts then without having to modify carriers etc ?
Can you shim the rear ?
Thanks
Posted 15th Dec 2009 at 20:30
looks like it yeah, I think BBM and AST do some topmounts that'll give a finer degree of adjustment than the Compbrake ones.
as for the rear no there's no way to shim them, there are camber kits though, Skip brown do them, as does Miles IIRC, or you can have your tailing arms modified by Martin (CRF_450 on here)
Posted 15th Dec 2009 at 20:40
r*byb
Ok, how do i contact skip brown as i cant find anything on google etc
Posted 15th Dec 2009 at 20:56
eh? they're the first result!
Posted 15th Dec 2009 at 21:15
smegal
Skip browns
Last time I was there there was a SHINY 205 being worked on.
Ex SC-6
Now in a Megane R26
Posted 15th Dec 2009 at 21:29
r*byb
Just spoke to Skip browns, they don't do them with camber adjustment
Posted 15th Dec 2009 at 21:35
