Author Subject: im so confusedededededdd
paule151
keep having to push start my car to start it, it only need sayy two foot and it starts i had alternator tested charging at 14.3 and 14.28 wth headlites on full beam i dont know what it is its a pain in the arse especially now in the winter months the battery all ways seems to be flat something somewere is wrong any ideas
paul.e.
Posted 16th Dec 2009 at 21:48
Welly Forum Admin
Dead battery? Knackered Starter
Vrs power!!
Posted 16th Dec 2009 at 21:49
cabbymeg
Dead battery? Just because the alternator is charging doesn't mean the battery is holding it.
Failing that, starter motor sticking maybe?
Edit: Beat me to it!
Posted 16th Dec 2009 at 21:50
paule151
would a dodgy starter be killing the battery, battery is new but got it online it was good for a week or so could it still be faulty tho
paul.e.
Posted 16th Dec 2009 at 21:55
cabbymeg
It could be, what happens when you try and start it on the key?
Posted 16th Dec 2009 at 22:01
paule151
jus clicks if its been runnin for say 10 mins it starts fine but otherwise loud clicking noise
paul.e.
Posted 16th Dec 2009 at 22:03
hbinky
Starter would only be a possible problem, as stated, if it was sticking, if this was the case the engine wouldn't turn over, it wouldn't drain the battery if faulty. Were you having charging / starting problems before the new battery was fitted? Have you got some crazy device plugged into the cigarette lighter?
Posted 16th Dec 2009 at 22:05
deadbattery Thumbs up
simonjames
Dead battery or bad conections on batery teminals
MY EBAY ITEMS
07943066306
Posted 16th Dec 2009 at 22:11
kellaway
When you go to start from cold, turn all of the car electricals on, then try and start - if all your lights dim and the starter motor clickes then the battery is fooked, if the lights all stay bright and the starter just clicks then its starter motor time.
Moonstone FTW
Posted 16th Dec 2009 at 22:12
paule151
yes was having star trouble so i replaced battery and no device in cig lighter strange lol
paul.e.
Posted 16th Dec 2009 at 22:27
paule151
wen i charge battery its fine but after a few day i have to push batt keeps dying why why WHYYYYYYYYYY!! lol
paul.e.
Posted 16th Dec 2009 at 22:29
simonjames
something is draining it then
its a prosess of disconecting things till you find whats draining it
MY EBAY ITEMS
07943066306
Posted 16th Dec 2009 at 23:03
Check the battery terminals are on ok and also check the earth points, the main one on top of the gearbox can cause all kinds of issues.
Check the wiring to the alternator as well. Could well be that if the battery is charging ok outside of the car. I know you've checked the voltage but even so...
Posted 16th Dec 2009 at 23:23
