Author Subject: Rear lights & Brake lights out.......Fuse/Relay
silky
Turning the lights on everything at the front is fine, however there is nothing at the rear apart from the number plate light.
Rear lights, brake light, rear fog, rear indicators
None of them come on
is there a specific relay or fuse that can knock them out ?
Thanks
Posted 17th Dec 2009 at 14:06
Check for where the lights are earthed?
Posted 17th Dec 2009 at 17:06
silky
It was dark so couldn't get a proper look, anyone know where they are earthed in the rear ? (thats if they are)
Posted 17th Dec 2009 at 17:07
check fuses, no relay for back lights i don't think, only front lights.. pull seat bench up and check the earth points near where the middle rear seatbelt lower part is. there are a combination of earths there which i believe are the lights and also behind the rear quarter panel on the passenger side
Posted 17th Dec 2009 at 17:08
silky
Cheers Rikky, gonna give that a go
May also be stalk at a guess
Posted 22nd Dec 2009 at 21:25
silky
Had a quick look today and still can't get them to work, will be trying another stalk later in the week
Any other ideas ?
It's all rear lights, so thats normal rear lights, rear fog, rear indicators, brake light and reverse light
Posted 28th Dec 2009 at 23:33
mr swampy s16
**BAD SELLER**
Which earths did u check?
Posted 28th Dec 2009 at 23:37
silky
None !
Silly I know but I couldn't work out where they were.
I checked all the wiring connections to the rear light units and also looked at the wiring under the rear seats, all seems ok.
Posted 28th Dec 2009 at 23:40
mr swampy s16
**BAD SELLER**
U need to take the earth bolts out.
Clean up the area under the connector then run a tap down the threads.
Maybe put some copper slip on the threads
Posted 29th Dec 2009 at 00:04
mr swampy s16
**BAD SELLER**
mr swampy s16
**BAD SELLER**
silky
Where are the earth bolts you are talking about ?
Posted 29th Dec 2009 at 00:29
mr swampy s16
**BAD SELLER**
Passenger side half way up the c post behind the trim panel and under the rear seat.
Could always just make some fresh ones up useing some cable a ring terminal and scotch blok
Posted 29th Dec 2009 at 01:26
silky
Also noticed that when I do put the indicators on that the light on the dash for them flashes really quickly
Posted 30th Dec 2009 at 02:05
it will do because the rear cluster isn't working, same happens when a bulb blows.
Posted 30th Dec 2009 at 02:12
silky
Ah right, gotcha Mei.
I'm gonna change the indicator stalk and then go from there, unless anyone else has an idea I can try in the meantime
Posted 30th Dec 2009 at 02:18
I doubt very much its that, I would unplug the rear light cluster and see if there's power and earth there with a multimeter.
if the whole lot is out I'd guess its either a major earth fault or a plug to the fusebox or similar up front inside is loose.
has the dash been out at all recently? or any wiring been played with near the door looms?
Posted 30th Dec 2009 at 02:23
silky
All wiring looks pretty solid, nothing been played about with and dash hasn't been out.
What readings should there be ? Got a multimeter but not used it before, a little explanation would be great, thanks
Posted 30th Dec 2009 at 03:36
pdd144c
Sounds like the earth if the number plate lights are still on, as said above earth runs up the passenger side c pillar.
Can be checked with a meter easy enough, turn to resistance and measure between the light cluster and the earth point. If the meter reads 0L the wire is broken so replace, if it reads near 0 ohms then the wiring is fine and it will be corrosion between the wiring contact and the car body.
FOR SALE
205 Turbo Technics complete and 306 Rallye Race Build breaking.
Posted 30th Dec 2009 at 03:50
silky
Ok thanks, will get the multimeter out later and give it a go
Posted 30th Dec 2009 at 15:28
