displaying posts 251 to 275 of 389
Pages (16): first .. 10 [11] 12 .. last
Author Subject: Ben306 rallye thread
jord294
Post #251
How the fook can it be 15mm out??
If you haven't removed at least one torsion bar to set the height properly, then you still haven't got it right
Posted 21st Oct 2021 at 20:58
ben306
Post #252
Thats how it arrived to me.
Took the bars out to level it up and to get the drop I wanted.
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 22nd Oct 2021 at 08:18
ben306
Post #253
Bit more spam incoming. Booked myself on a last minute trackday at Blyton to get the bug back so meant I had to finish getting the track wheels sorted pretty sharpish after the best part of several years being half stripped....
So finished stripping/sanding them back, primed, dark metallic grey, lacquered, new centre caps and decals. Wrapped in some Nakang NS2R track tyres.
3 sisters circuit
Few laps at Blyton
Posted 8th Dec 2021 at 16:06
ben306
Post #254
While I had the rattle cans out, decided to sort out the tailgate from being de-locked that had seen better days from being stood on the drive for so long etc
Not a bad rattle can fix although not a perfect match. I really need to give the compressor a go and do a proper job with things like this. Time to treat myself to a proper spray gun and get brave
3 sisters circuit
Few laps at Blyton
Posted 8th Dec 2021 at 16:10
ben306
Post #255
Also replaced the dead solenoid so I can open the tailgate again...
3 sisters circuit
Few laps at Blyton
ben306
Post #256
Finally gave the car a good once over, check of all the fluids etc. and sorted the brakes for track time.
Replaced the DS2500 (use these for the road) with some DS3000 pads and fitted some standard Pagid Discs (the DS3000 are hard on discs so didnt want to destroy the Tarox which are 10x the cost of the Pagid - so the tarox are left for the road with the 2500 pads)
Still not got the oil temp working and still questioning the water temp as it only got to 80C even after several laps on the limit.
And fitted a sunstrip as its that time of the year with low sun etc.
3 sisters circuit
Few laps at Blyton
Posted 8th Dec 2021 at 16:17
ben306
Post #257
Finally got my trackday in at Blyton - Had a steady morning as after 10 years of not seeing a proper track I wanted to make sure the rallye and me were up to it. Soon got back into it and by the afternoon was back pushing the limits again.
Car held up great. Definitely got the bug back and looking to book something again in the new year. Need to replace the creaking steering rack and damaged front subframe.
Believe it or not, was the 1st time of using track tyres as I've always tended to run Michelin sports as I can pick up a set of ex ginetta tyres for £100 a set, the difference was night and day, really surprised me tbh.
Anyhow, few shots from the trackday. Even Maggie (my trusty LaCool got a ride in the rallye as she stayed with a friend for the day while I was out....
3 sisters circuit
Few laps at Blyton
Posted 8th Dec 2021 at 16:24
ben306
Post #258
Finally, few quick clips/ laps from Blyton
https://www.youtube.com/watch?v=Agkesq0kqFA
https://www.youtube.com/watch?v=RUMP8jRg72E
3 sisters circuit
Few laps at Blyton
Posted 8th Dec 2021 at 16:29
ben306
Post #259
bit of an update
Recently got myself a fresh steering rack and front subframe after the current one took a decent hit. The rack had a really bad "creak" that I couldnt get to the bottom of and the subframe was out of shape meaning the exhaust would vibrate on it on full chat.
So decided to clean up the replacement subframe, seam weld it, treat it and paint it.
Gave the replacement rack a clean up, paint and fresh TRE etc.
Cleaned up and painted the bottom arms and replaced the roller bearings and inserts for the RB bushes.
Also came across a little rust spot where the subframe mounts so that got cut out and welded up/ treated and painted.
While I was at it I gave the sumpguard a fresh paint.
Fitted Baker BM Group N gearbox Mount and Group A Fork Bush as they were the only ones left to upgrade now
Also got a fresh set of track tyres while they were on a deal in the Jan sales for once my current ones have died.
Next trackday is Anglesey on 19th Feb, then got an evening event at 3 sisters 2nd March then 24th April at Blyton for the Performance French Car trackday.
Got the wheel alignment sorted Saturday so should all be good to go now, probably just give the brakes a fresh lot of fluid but may be a tart and give the brakes a paint yet.
3 sisters circuit
Few laps at Blyton
Posted 24th Jan 2022 at 15:03
Post #260
Nice update.
I'll be at Blyton on the 24th albeit not on track in mine. I'll hopefully be passengering with some mates but I'll probably take my diablo '6 to stick in the parking area as it's looking pretty mint after a recent respray. I'll come over and say hi at some point Thumbs up
Posted 24th Jan 2022 at 18:10
Post #261
Nice update and great work Ben Thumbs up
How did the subframe get hit and damaged like the ?
Posted 25th Jan 2022 at 15:34
ben306
Post #262
prism7guy wrote:
Nice update.
Thanks. Mines in need of the bodywork sorting but figured a year of giving it beans on track again first will be time best spent then I'll look to give it a respray.
3 sisters circuit
Few laps at Blyton
Posted 25th Jan 2022 at 22:54
ben306
Post #263
Hit a massive rock in the road, couldn't avoid it. Lucky I had the sumpguard as that did its job.
3 sisters circuit
Few laps at Blyton
Posted 25th Jan 2022 at 22:56
ben306
Post #264
Decided to be a bit of a tart and give the brakes a cleanup and paint. Calipers werent in bad nick as refurbished 2 years ago so seals etc all good, just wanted a good clean up, removed the sliders and a smear of copper slip etc. Figured Id do the rear carriers to match as I had a couple of sets spare
Rears wire brushed right back to clean metal and rust treated.
The G88 discs are for the road, too expensive (10X the cost of the standard discs I used for track) to ruin them on track as the DS3000 pads I use are pretty harsh on discs. I just accept the squealing on track Smile
Come to swap the rear carriers and whats with the peugeot 5 sided bolts!!!!!! (The beam/axle was a refurbed beam I bought last year to get the rallye back on the road so 1st time of removing these carriers) Couple of old sockets and big hammer to finally remove them, normal bolts back in
Rears done to complete the "tartiness"
I'll try and get out for a bit of a blast in it next week just to make sure everything is feeling ok ahead of my next trackday at Anglesey in 2 weeks time.
3 sisters circuit
Few laps at Blyton
Posted 4th Feb 2022 at 10:22
ben306
Post #265
Finally got hold of the right clocks/dials so now I can keep and eye on oil temps again.
Also fitted a working stereo so I can try and drown out the noise while driving to and from trackdays haha. Not very "trackcar/racecar" but there you go. Nice old school Ipod compatible Kenwood I've had sat in a box for 15 years.
And I've also gone a picked up yet another set of wheels, some more Comp2's but in 16s now. Think I'll paint these up white to use on the road. But looking at the stack of wheels and tyres now it looks like I may have issues haha
Took the motor out for a B road thrash last night to check everything felt ok after all the work I'd done on it. Few small tweaks needed but should be good for Anglesey next weekend now.
3 sisters circuit
Few laps at Blyton
Posted 11th Feb 2022 at 08:40
Post #266
Look forward to seeing some pics and footage Ben Thumbs up
Fairplay to you for all the hard well .
Posted 12th Feb 2022 at 08:30
ben306
Post #267
Far from the levels of engineering and effort you've put into your motor LOL
But its good to be having fun in it again. Although looking at the forecast for Anglesey, I think its going to be the road wheels and tyres as its weather warnings and very wet....
3 sisters circuit
Few laps at Blyton
Posted 14th Feb 2022 at 08:32
ben306
Post #268
Well with the current storm and forecast heavy rain/sleet and snow forecast for tomorrow at Anglesey Circuit, I've played it safe and swapped to my road wheels and tyres. Still thrown the track wheels and semi slicks in the back, if there isnt too much standing water, I may put my big boy pants on and try them later in the day so I get an idea for future days if its wet etc.
Given the car a once over, checked levels/pressures etc, rain x and anti fog the windscreen/front glass as figured it may help.
Early start for the 2.5hr plus drive down, at least I'll have a radio to listen too this time and drown out some of the rattles and road noise Smile
Does look good on these speedlines tho.
3 sisters circuit
Few laps at Blyton
Posted 18th Feb 2022 at 15:52
Post #269
You mean spending stupid money on a £1k-£2k car i cant see me driving for another 14months….its now a obsession project Crazy
Ben ive been where you are and i had the most fun with a standard Engine 8 injectors and a uprated ECU and loom and uprated brakes and suspension / wheels Thumbs up
Sadly mines turned into a garage project and im enjoying working on it more than driving it ( not good )
Only good thing ?….Its kept me sane through Covid and Skint
Love the updates and especially the great pics A credit to you Ben
Posted 19th Feb 2022 at 10:34
ben306
Post #270
Few shots from Saturday. Was a very wet and windy day but the rallye didnt seem to mind it and was a bit of a "leveller" in terms of a lot of the more high powered modern stuff there.
3 sisters circuit
Few laps at Blyton
Posted 22nd Feb 2022 at 13:26
ben306
Post #271
Fitted a quick release to bring the wheel closer as found I was stretching a little at anglesey.
Got a track evening at 3 sisters tomorrow so will see how it feels
3 sisters circuit
Few laps at Blyton
Posted 1st Mar 2022 at 16:01
Post #272
What time at Three Sisters?
Posted 1st Mar 2022 at 16:30
ben306
Post #273
5-9pm Thumbs up
3 sisters circuit
Few laps at Blyton
Posted 2nd Mar 2022 at 08:41
Post #274
Is it an open track day as can't find any info on their website?
Posted 2nd Mar 2022 at 13:03
ben306
Post #275
Extreme BHP - its a re-scheduled day from October that got red flagged and cancelled due to flooding/bad weather.
3 sisters circuit
Few laps at Blyton
Posted 2nd Mar 2022 at 13:25
