Author Subject: Air con removal
cornish_pug
My air con hasn't worked since i've had the car, about 3 months. I'm looking 2 remove it, Is it an easy task 2 remove the whole air con system, and wot needs 2 be done?
Team Diesel
Posted 27th Dec 2009 at 08:07
Get a Rallye alternator belt setup and remove any pipes, condenser, etc.
Posted 27th Dec 2009 at 09:55
ablister
easy to see what to do but hard to do it if you get what i mean. Pipes can be tricky to remove and quite fiddly to remove some of the bits + bobs
306 rallye, Richard Longman engine
rc10gt
Posted 29th Dec 2009 at 01:55
denwar
rallye belt does not work, its about 30 mil too short, tried it on mine as i did away with aircon when engine was out, ended up keeping the compressor and using my original belt.
denwar
Posted 2nd Jan 2010 at 01:46
You need the Rallye alternator belt setup, i.e. the belt tensioner, pulleys, etc and then use the Rallye belt.
Posted 2nd Jan 2010 at 03:30
denwar
thatl explain why mine didnt work then......siimples
denwar
Posted 2nd Jan 2010 at 15:41
turbowagon
or 2.0 xsi set up works too ive got that on mine
slowest project car ever.com
Posted 2nd Jan 2010 at 15:46
fozzy_255
Im taking the air con off my xsi ph3 , the rallye set up will fit this engine too right as same block?
Posted 2nd Jan 2010 at 21:58
