Author Subject: knocking coming from head
lilnickgti6
hey guys wondering if anyone has any ideas. when at idle i can hear a knocking coming from the head, sounds like a bolt rattleing round inside.lol its definitly coming from inside the head, only happens on idle if i rev it as soon as it gets back to idle its knocks? is my engine about to blow up????;lol
Posted 17th Jan 2010 at 22:14
Have you checked your spark plugs are done up tight?? Unsure
Well worth a check in my opinion. Yes
Stan.
Posted 18th Jan 2010 at 00:38
phil19gti
I had a knocking last week. Checked the spark plugs and one was loose. Noise has gone now.
2006 Performance Blue Mondeo ST TDCI
1999 Black 306 Rallye
1991 Lazer Green 205 1.9 GTi
2003 Blue Focus RS
1999 White 306 Rallye
1992 Red 205 1.9 GTi
1988 Red 205 1.6 GTi
Posted 18th Jan 2010 at 01:30
smithy27eng
LOL
306 gti 6 bpl
Posted 19th Jan 2010 at 04:23
lilnickgti6
had all new spark plugs put in, knocking still there, anyone have any more ideas?
Posted 19th Jan 2010 at 23:39
bent valve, rattling big end bearing.
Posted 20th Jan 2010 at 00:00
peugeot dave
maybe a knock sensor is at fault, i would get a diagnostics read out done, if its any electrical fault it should come up with the fault saving you lots of effort and time.
failing that try high octaine fuel.
my car's spending all my money grrrrrrrrrr
Posted 20th Jan 2010 at 00:06
lilnickgti6
high octane fuel?? the sound is coming from the cam area on the right side
Posted 20th Jan 2010 at 00:09
lilnickgti6
think i might of found something........
a while ago i onpened the oil filler cap and there was a piece of black plastic that had snapped off something, I think it could be one of the bits ive pointed to on the picture. what are these plastic things for?? the problem with the knocking im getting now i think it might be abit more of the plastic rattleing round in the head
lilnickgti6 has attached the following image:
Posted 20th Jan 2010 at 00:43
It is part of the oil spray bar.
Posted 20th Jan 2010 at 00:54
lilnickgti6
doesnt seem to be any problems with oil, definitly lots of oil getting in there lol( i opened the oil cap while engine running, with a nice fresh cleaned engine bay lol.) do you think it might be abit of the plastic bit stuck in there knocking about?? how much roughly would it cost to open the head up and have a look? is it big job?
Posted 20th Jan 2010 at 01:24
You just need to remove the cam covers with a Torx bit.
Posted 20th Jan 2010 at 03:23
lilnickgti6
really as simple as that? any gaskets? i dont have much knowledge about engines, could i damage the engine opening it up?
Posted 20th Jan 2010 at 20:35
jmh306
i removed my cam cover for spraying last week the gasket is build in on the cam cover so you should be ok removing it Smile
FB: South Downs French Car Club
Diablo 6 2001 low boost
Diablo 6 2000 100% standard working air con
Vw Caddy tdi work van
Posted 20th Jan 2010 at 23:26
peugeot dave
you say a rattle\knocking sound at idle is it only at idle or does it rattle more through the rev range?????
the reason for high octaine fuel is the engine has knock censors and will adjust the timing to suit the fuel (basicly) its worth a try.
also if the plastic you broke off was a small piece surely it has gone through into the oil filter!!!
can you remeber how big it was?
Posted 21st Jan 2010 at 03:50
peugeot dave
would this not be worse with the engine increasing revs???
Posted 21st Jan 2010 at 03:53
If its a bent valve or rattling big end the tapping will remain throughout the revv range, i should no, my 6 had 10 bent valves when i bought it! Good job i already new that and had a head ready lol.
More likely to be a warn out hydraulic lifter if it goes away when rev'd up or doesnt always do it.
Posted 21st Jan 2010 at 05:18
lilnickgti6
hydraulic lifter. is that a big job?
Posted 23rd Jan 2010 at 05:28
a head rebuild and a head skim
Posted 23rd Jan 2010 at 08:04
smithy27eng
that is whats happened to mine took it to garage today found out that the water pump had gave in causeing the cambelt to have play in it basically on the verge of coming off which has had a knock on affect on the cams which have been bouncing around because the belt wasnt tight enough hope this helps
306 gti 6 bpl
Posted 23rd Jan 2010 at 16:22
if the black plastic thing has come off then wont the oil spray bar be in 2 pieces??
hence another bit of oil bar loose in there, and not enough oil getting to the end area where its missing??
just a thought
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 23rd Jan 2010 at 17:15
lilnickgti6
found exactly where the knockings coming from, its the vacuum pump, going to try replacing that and good oil change
Posted 31st Jan 2010 at 02:24
