Author Subject: timing belt failure!.
gon2o
my timing belt decided to snap on friday, stripped and rebuilt the head, i have set the cam and crank on there marks, manualy cranking on these settings, the whole lot is locking up... whats going on? Wink
Posted 19th Jan 2010 at 20:01
rich_w
My guess would be the crankshaft pulley on your engine is fooked, and the outer part has rotated independantly of the inner part - so the timing hole is in the wrong place.
The angle between the keyway and timing hole should be 75 degrees.
You may have to re-build it again if it locked up when turned over by hand - depening on how hard you were doing it.
The valves bend very easily.
Sad
Contact Details:
07732 822546
Posted 19th Jan 2010 at 20:06
how did you set them by marks? there are none, you use pins.
as Rich said, the bottom pulley is often damaged and places the pin hole in the wrong place and if you have forcefully turned it over by hand you will bend the valves.
Posted 19th Jan 2010 at 20:12
