Author Subject: Baffling water leak
jamiebhoy76
Hi, i seem to be losing a helluva lot of water from my cooling system. The car has overheated once or twice over the past few months due to the loss of water, but it seems to be more frequently as of late.
I can't see water dripping from anywhere at all. When i top up the water through the radiator cap its taking a minute or so for the water to make its way round to the bleed point at the top of the radiator on the other side, which seems to be bubbling quite a bit before the water arrives.
There is a very minor build up of pressure sometimes but this make be due to the water loss.
The heating in the car is superhot, the car has not long been serviced and the oil looks fine.
I did however notice a very gentle hissing noise coming from the left of the engine as you look in from the front. It was stopping and starting again, just after i had ran the engine for a while.
Any ideas lads?
Posted 19th Jan 2010 at 23:08
justinaccurate
Head gasket maybe? Sad They dont take too kindly to overheating at all
What does the underside of your oil cap look like?
Posted 20th Jan 2010 at 01:12
jamiebhoy76
It looks fine, the oil is normal, no water getting in to it. Blink
Posted 20th Jan 2010 at 01:44
jamiec
hi mate mine has just done exactly the same thing and found out it was a knackerd water pump check that make sure its ok.
Posted 21st Jan 2010 at 23:25
rcarney1989
yeah sounds like my xsi check water pump but lack of leaking water / no puddle + pressurized system makes me think head gasket on my xsi few months after water pump went the head went but was blown between cylinder 1 and 2 so water was not reaching the oil but i was losing water fast was going into 1 and 2 then strait out the exhaust valves
head gasket looked original and was very very rotten
have it looked at my friend and sniffer never showed up a thing also mite be down to the water not reaching the over flow bottle tho
parts cost me 200 quid thats including water pump and belt bolts gasket set etc add another
Team:Kuwait Working :<
6 is in the uk in my garage :<
but shes going high boost when i return to the uk Big grin
Posted 22nd Jan 2010 at 00:08
jamiebhoy76
Water pump seems to be working fine. Have opened the bleed point next to the top of the radiator and the water is flowing fine.
Posted 22nd Jan 2010 at 02:47
allesclar
whats the condition of the rad?
Team allesclar ®
Posted 22nd Jan 2010 at 02:51
:: blade ::
my pug is doing the exact same thing atm, bar it over heating, hope its the waterpump, will get it check out as soon as Smile
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
jamiebhoy76
Rad seems fine. The only clue to the problem is i can hear an extremely faint hissing noise from the left hand side of the engine, looking into the engine bay.
On top of this, today the car developed an irratic idle. Up to 1500k then down to 500k repeatedly before stalling. Starting back up ok, but problem persists.
Posted 22nd Jan 2010 at 02:56
:: blade ::
hope you find the problem mate, mines been doing the same since the beginning of the week, put around 10ltrs of water through it last night, not a clue where the water is goin as i couldnt find any drips or anything from the engine when it was idling, soo confused
Black Ph1 XSi-6
Posted 22nd Jan 2010 at 03:00
jamiebhoy76
Same boat mate. Not going thru as much coolant as you, but can't see where the water is going.
Cars running fine too, apart from the new idle problem!
Posted 22nd Jan 2010 at 03:08
:: blade ::
i had the idle prob a few weeks back, sorted that last week with a new ICV, then this happens, altho when i took it for a quick run around the block last night when i had water in the rad, got back and it was empty, with no signs of a leak on the road or anything
Black Ph1 XSi-6
Posted 22nd Jan 2010 at 03:14
jamiebhoy76
ICV?
Thats some amount of water to lose?!
Posted 22nd Jan 2010 at 03:20
:: blade ::
idle control valve Smile
Black Ph1 XSi-6
Posted 22nd Jan 2010 at 03:23
jamiebhoy76
lol
I'm thick! Are the ICVs specific to each 306 model?
A mate has a spare ICV he took out a 306td, could i use this in my GTi-6?
Posted 22nd Jan 2010 at 04:25
cooper666
sure d turbos dont have a icv Confused
clio r27
ps3 id:cooperkloe
Posted 22nd Jan 2010 at 04:35
rcarney1989
this was exact same as my car fill it up do less than a mile and no water at all check for water in exhaust boxes shake them about listen for slushing or jack the car up from the front so the exhaust is at an angle water may dribble out or steam while running at normal temp etc because this sounds like the gasket is gone failing that u have a cracked head/block this is just past experience i have had so just advice
Posted 22nd Jan 2010 at 05:17
jamiebhoy76
XSi!! LOL
Posted 22nd Jan 2010 at 06:02
:: blade ::
yea getting a compression test and pressure test tomoz so will see what that brings back, driving up to preston soon,so will fill up and see how it goes on the 30-40mile trip,. last week it was fine on the long journey, but crap on a short one :S
Black Ph1 XSi-6
Posted 22nd Jan 2010 at 22:31
al4x
Head gasket has gone hence the bubbles in the system, it can take ages for water to appear in the oil especially if the leak is letting coolant into a combustion chamber as you simply put it out of the exhaust
Posted 22nd Jan 2010 at 22:34
:: blade ::
just filled it up, went for a 15min drive, longer than the other day, and the water level stayed as it was and didnt lose any, will put up the info i get from the pressure test on the coolant system and the compression test Smile
Black Ph1 XSi-6
Posted 22nd Jan 2010 at 23:59
:: blade ::
Well getting the compression test done next week instead as the garage was busy but got a pressure test done, it found a few holes in a couple of coolant pipes so will be fixing that this week, also it didn't lose any water on the drive up to Preston last night
Black Ph1 XSi-6
Posted 23rd Jan 2010 at 18:41
