Author Subject: Bottom end rebuild...
availablebmx
Just got a rough price from a reputable local garage of around
Thomas - Black 6 rollin' on black 15's...
197bhp - 155.8bhp/135.4ft-lb atw
Posted 3rd Feb 2010 at 19:43
you haven't said what's included in that price, Autodata states its 28 hours for a complete engine, 25 hours for a bottom end alone or 8 for a cylinder head remove inspect and refit.
to do it properly you'd have to take the head off as well to change the piston rings, in which case you might as well get the head checked and fit new valve stem seals and a headgasket at least.
If the head isn't coming off though they're just doing the main and big end bearings, that's about
Posted 3rd Feb 2010 at 20:08
jonnie205
Is that with you taking them the bottom end or are they stripping it out? its a huge amount of work if they are removing and rebuilding. Whats wrong with the engine?
Posted 3rd Feb 2010 at 22:34
availablebmx
Well I'm not totally sure what work is going to be envolved as they are going to inspect the damage... But as a rough idea to rebuild the bottom end he said 6-700!
I done a bearing at my last track day whilst the engine was running with 140degree oil temps...
Oil cooler on the list me thinks Smile
Posted 3rd Feb 2010 at 23:51
i think that sounds well cheap, surely they cant be fully rebuilding it new for that?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 4th Feb 2010 at 00:53
pdd144c
And you kept driving it?! That price seems very cheap.
FOR SALE
205 Turbo Technics complete and 306 Rallye Race Build breaking.
Posted 4th Feb 2010 at 02:56
miles
As said depends on what they will do, A crank out, Grind (If possible with a spun shell), Bearings and Seals etc is a good
www.pugracing.com
Posted 4th Feb 2010 at 03:20
r*byb
Off topic are there any updated shells? Are these acl bearings same price?
Team Low Compression
Posted 4th Feb 2010 at 03:23
rich_w
The ACL bearings are the ones I supply which are also available through Miles @ Pug Racing.
They are a tri-metal construction, mainly made up of copper with a lead overlay, and are much more durable than the OEM alu-tin type bearings.
They also have a fractionally bigger running clearance, for better oil flow, to improve lubrication and heat dissipation.
Smile
Contact Details:
07732 822546
Posted 4th Feb 2010 at 04:25
rich_w
As for the rebuild price, I would guess that is the price for replacing the crank / shells in situ rather than taking the engine out.
There's nothing wrong with doing it that way, unless the failure is severe, and the bearing has spun around within the cap. If this is the case, you will have to take the engine out, get the head off, and replace suspect rod, as the big-end will be stretched and out of round.
Your bill will be much bigger then.
Rich.
Contact Details:
07732 822546
Posted 4th Feb 2010 at 04:29
how much is a set of std size big ends?
Posted 4th Feb 2010 at 04:57
rich_w
Contact Details:
07732 822546
Posted 4th Feb 2010 at 15:18
availablebmx
I might have to get them of you then rich, along with one of your lightened and balanced flywheels...
I'll pm you soon Smile
Posted 5th Feb 2010 at 04:56
