Author Subject: Problematic Fans - Help?
oecken
Both my Fans seem to be coming on randomly, have checked the Brown sensor and all seems to look fine, not that dirty either... what other things could it be, Engine / Temp etc acts as it should.
could it just be dirty inside the sensor itself so not making a connection?
Ta'
Posted 4th Feb 2010 at 01:57
mpaul
My 1.6 glx used to do this. I cleaned the sensor and blasted it with wd40 as well in case there was water in it.
It actually turned out to be losing coolant due to a perishing pipe, which eventually let go at 70mph, leaving me stranded and waiting for the AA.
I would definitely try cleaning it first. See if that makes any difference.
Posted 4th Feb 2010 at 03:14
gti6-ginge
had this problem turned out to be the fan control unit (bitron) located behind the wheel arch liner on the passenger side they fill up with water and coroade the terminals causing the problems you have givin. replaced mine and sealed it in a zip bag to stop water getting in. hope this helps
MY CAR WAS BUILT ON 17/03/2000 THATS A FRIDAY OH NO
Posted 4th Feb 2010 at 04:05
psjunkie
thought the bitron was next to the ecu or is that jus me! LOL
1997 P1 Gti 6 Charged
Posted 4th Feb 2010 at 04:40
farmer
Your thinking the double pole relay are you not?
Black and red thing, attached to the back of the ECU box.
As said, bitron is up behind the NS wheel / arch.
Long live the Sigma 6 Big grin
Team Phase 1 supercharged
XBL ID: farmer uk1
Posted 4th Feb 2010 at 04:43
technically Bitron is a manufacturer of electrical components, namely relays electronic control units and sensors, the relay is made by bitron, the brown sensor is made by bitron, the cooling fan/a/c control unit is made by Bitron, the central lockign unit is made by Bitron, etc
Razz
Laugh my ass off
Posted 4th Feb 2010 at 05:01
oecken
soooo... if it the "Bitron" is this expensive Sad
im guessing it may have something to do with the previous owner removing wheel arches to fit 17's on Doh
Posted 4th Feb 2010 at 15:28
ewenmac123
i had same problem and have just finished cleaning the bitron unit and problem solved. just take it of and give the terminals a clean with wd40 and dry it should do the trick
dooby
Posted 5th Feb 2010 at 00:17
oecken
okay cheers buddy, i know there only about
Posted 5th Feb 2010 at 00:32
cwspellowe
I think you're beginning to see the difference between want and need LOL
Bye bye Sundance Kid Sad
Posted 5th Feb 2010 at 15:42
oecken
i dont know what your talking about Whistle buts its only
Posted 5th Feb 2010 at 17:01
bubbagti6
I had the same with mine. took it (bitron) out clean back in bobs your unncle. if that fails there are 3 relays under the grill which also control the fans hope it helps
They may take my crayons
but they'll never have my windows
Posted 5th Feb 2010 at 18:22
oecken
Cheers Bubba, il try that first!
Posted 5th Feb 2010 at 21:45
chrisd306
where is the bitron unit and where is this brown switch your on about as ive got a 6 that the fans arent working on, im looking at just putting in a relay and a switch as probly cheapest option.
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 5th Feb 2010 at 23:39
brown sensor is in the thermostat housing, relays in the middle of the fans.
don't use a switch, that's just a bodge waiting for an eric when you forget to turn it on....
Posted 5th Feb 2010 at 23:46
chrisd306
well i changed the relays an it never done anything, so what else is there to check? if i pull that brown switch off the fans should kick in??
on my rallye its got orginal wiring for fan so it runs as normal but when on the track on the cool down lap ive got it to a switch which kicks the fans in at a quicker speed, all wired up good, not by me tho lol
& Audi Q5 S Line
Posted 6th Feb 2010 at 00:13
have you checked you have power to the relays? try manually switching the relays with a power probe, the fan would come on then, IF its not seized which is very common.
another fault can be the control unit.
Posted 6th Feb 2010 at 00:16
chrisd306
there is power to fans as checked with probe
& Audi Q5 S Line
Posted 6th Feb 2010 at 00:26
chrisd306
they both spin by hand easy enough
& Audi Q5 S Line
try switching the relays with the probe then Thumbs up
Posted 6th Feb 2010 at 00:36
chrisd306
tried that didnt work mate
& Audi Q5 S Line
Posted 6th Feb 2010 at 04:18
dead relays or a dead fan then Thumbs up
Posted 6th Feb 2010 at 04:38
chrisd306
will try powering the fans, looks like there is a red wire (prev bodge) going from relay box bit to the main loom, think its going to be best sticking a switch on rather than trying to sort it out as the guy isint wanting to spend alot on it really.
& Audi Q5 S Line
Posted 7th Feb 2010 at 06:04
furry muff, he'll be back for a headgasket not too long wishing he'd spent the cash fixing it properly LOL
or the new owner will be anyway....
Posted 7th Feb 2010 at 16:19
chrisd306
thats why it was in as he thought the HG was away but was only a f*cked rad cap and fans not working, he doesnt use it that much so would end up being the next owner, will have a proper loo 2m, as been busy with my own stuff
& Audi Q5 S Line
Posted 7th Feb 2010 at 22:53
