Author Subject: Rear Brake pad retaining bar/clip
davedgti6
Hi peeps, i've just put a new set of rear pads on complete with a new fitting kit, i lost a brake pad (fell out) as i was doing approx 70mph (made one hell of bang ), i'm now a bit paranoid of it happening again,
My question is does the little clip (figure of 8 thingy) definately go through the hole in the retaining bar that's on the inside (i.e. the furthest hole away from the wheel?, it does show it that way in Wellys Faq but i am sure i did it that way last time and the pad still fell out? Unsure
Can someone confirm if this is correct?
davedgti6 has attached the following image:
Posted 7th Feb 2010 at 17:55
yes.
Posted 7th Feb 2010 at 18:17
davedgti6
yes.
Thank you Smile
Posted 7th Feb 2010 at 18:56
tvrfan007
Yep that's deffo right. Mine fell out once but the L clip, and subsequently the pads, stayed in place.
I can only think your pad springs weren't in right previously? Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 7th Feb 2010 at 23:57
or the bar was worn Smile
Posted 7th Feb 2010 at 23:50
davedgti6
no I definitely did them right last time, dunno really why i spat out a brake pad at 70mph, hopefully the new fitting kit should keep these ones in Smile
Posted 8th Feb 2010 at 00:52
jim01uk
Have you put both legs of the clip through the hole? that's what it looks like in that picture, and that's not right. ??
Posted 13th Feb 2010 at 02:02
yes that is right jim!
Posted 13th Feb 2010 at 02:05
jim01uk
I've always put one of the legs through the hole and one around the outside as it limits the travel of the bar further!
Posted 13th Feb 2010 at 02:33
cress87
I don't suppose it makes much difference either way. All the ones I've seen have been like the picture above though.
Posted 13th Feb 2010 at 02:35
anthony
A good fix for the problem is to do as the 205 rally boys often do and drill an extra hole in the pad carrier and lockwire the bar in place - no way that it's going to fall out then.
1989 Eunos Roadster // 1992 Peugeot 205 GTi-S 1.9 // 1999 Peugeot 306 HDi Meridian
Posted 13th Feb 2010 at 02:55
