Author Subject: Knocking from rear...again
davek671
Bad knocking from the rear when going over bumps and braking. Im assuming its the rear beam mounts, the rear mounts seem ok, but the front ones may well be knackered.
Ive refurbed a 205 Gti rear beam before and there were only bearings etc inside the beam itself, is it the same on the 306 beams?
Trying to narrow down the options before i start taking the mounts off.
Cheers, Dave
Oh you pretty chitty bang bang, chitty chitty bang bang we love you!
Posted 7th Feb 2010 at 23:56
you can't really tell till you take the mounts off if they needed replacing, and in many cases ones that have worn enough to cause knocking often don't look worn at all once off Doh
the trailing arm bearings are exactly the same as a 205 and dont tend to cause any knocking noises when they wear badly.
I'd budget in
Posted 8th Feb 2010 at 00:09
smithers
Yes very similair setup to the 205, just bolted mine back on yesterday after a complete rebuild.
Have a look Here
And also in the FAQ section there are a few good guides Thumbs up
1997 Black GTi6
smithers205 at hotmail.com
Posted 8th Feb 2010 at 00:10
davek671
Cheers for the replies. Refurbing the 205 beam really wasnt enjoyable, so i will just change the bushes for now. LOL
Is it possible to swap the mounts without removing the beam from the car? Or atleast just lowering the beam enough to get access?
I just replaced the brake pipes for its last MOT and rather not disconnect them unless i have to.
Cheers again.
Posted 8th Feb 2010 at 00:27
smithers
Cheers again.
Yes mate the mounts are do-able on the car, have a look in the FAQ section Thumbs up
1997 Black GTi6
Posted 8th Feb 2010 at 00:55
wont need to disconnect the lines, just unclip them from the boot floor, I managed to do mine on my own in an hour and a half odd, just drop it down enough to get at them Smile
Posted 8th Feb 2010 at 01:05
