Author Subject: power steering removal
rallye1999
whats the steering like without power steering?
i fancy removing mine for less weight but im unsure on:
if i remove the ram i think the tyre will rub on a six speed box?
just a case of making a manual tensioner and shorter belt?
Posted 8th Feb 2010 at 18:02
Depends on your suspension setup as to how heavy it will be.
It will rub yes without the ram. Could weld the rack to stop that.
I'd have thought so - can't recall offhand.
Posted 8th Feb 2010 at 18:09
sod all extra weight tbh compared to other parts you could lose, more benefit from spending a little more cash on wheels lighter brakes etc.
is it a rally car with a nice tight diff? I'd keep the PAS if so Smile
S16 non a/c alternator bracket is ideal for this as its a hell of a lot lighter and easy to fab an adjuster using 8v 205 alternator adjuster rod, you would need the top engine mount bracket as well as its a 2 part one on nthem.
Posted 8th Feb 2010 at 19:34
anth
I removed the aircon and power steering from my old car.
Removing the ram will scrape the box on full lock. but it doesnt take long to remeber how far you can turn the wheel.
In terms of heavyness you will gain muscles in your forearms pretty quickly when dry steering/ moving slowly.
When driving faster i prefer no PAS. It picked up the revs alot quicker as i was running alternator to crank without tensioners.
Posted 8th Feb 2010 at 21:59
clen666
Was thinking of doing the same so I may wait and see the outcome of this thread Ninja
Team 'unintentional rat look'
Posted 8th Feb 2010 at 23:49
rallye1999
Car doesn't have a diff and will be mainley for track, although will be used for a bit of b roads, a lot of engine bay is already stripped off so thought a bit more weight and, inertia from the crank would be good, will see what I think as I havnt done much lately as my garage is full and it's allways dark lol
Posted 9th Feb 2010 at 00:18
