Author Subject: Update: Not starting first time!
ar4ibaldo
When starting in the morning or after work, it doesn't want to start first time, but fires up the 2nd time you try it.
Below is the quick vid..... any ideas what the problem might be?
View My Video
Posted 15th Feb 2010 at 22:29
jaydog81
Sounds fuel/ spark plug/ coil related imo mate.
Give them all a check over.
*jay81.
Phase 2.5/S-99
Team i live for working,Paying bills and funding my hobbies. I wish my life could be just living for a pink "I love the 6 sticker".Laugh my ass off
Posted 11th Feb 2010 at 01:20
ar4ibaldo
Thanks Jay, will look at them on saturday.
Any other suggestion guys? this is driving me nuts!!
Posted 11th Feb 2010 at 21:54
spike_uk06
Does the car misfire or hesitate or stutter when you're driving it?
Team China
Team Pirelli
Team Cracked Bumper
92k
20th Nov 1999 she was born
Posted 11th Feb 2010 at 22:04
lotek
when you turn key can you hear fuel pump priming?
when was it last serviced?
Posted 11th Feb 2010 at 22:12
ar4ibaldo
Serviced about 3 weeks ago, with new oil filter, inc fuel filter. Pug OE parts used.
When turning the key, fuel pump is priming.
After the service was starting fine, this issue developed in the last couple of days.
Neither. However i should mention that when starting it today at work it wouldnt start at all, sort of almost firing up but cuttin out immediately. Finally started on the 4th attempt.
Posted 11th Feb 2010 at 22:47
spike_uk06
Could be the TPS.....
Team China
Team Pirelli
Team Cracked Bumper
92k
Posted 11th Feb 2010 at 22:53
dan_s16
IIRC if the cam position sensor dies it makes them difficult to start
Posted 11th Feb 2010 at 23:21
mabgti
NV motors
Interesting.. my mate has the same prob.. gotta feeling its either cam sensor or fuel relay!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 11th Feb 2010 at 23:27
darkgti6
Mine does this sometimes, runs fine and then just doesnt want to start - it even pops when trying sometimes.
Take the key out try again and it starts just fine, im thinking it could be an ignition barrel fault, immoboliser fault or loose connection in the steering coloumn somewhere!
Edit, it cant be the cam sensor or flywheel sensor because these have both been changed already!
Team Peugeot Sport 308 Gti�
Posted 12th Feb 2010 at 00:21
davedgti6
Mine always does this, always starts second time though so not a problem
Posted 12th Feb 2010 at 00:27
mabgti
NV motors
Think the SC cars take a few turns to fire anyway.. prolly cos of the charger spooling a few psi on crank..
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 12th Feb 2010 at 04:23
ar4ibaldo
Where can i find the cam sensor and fuel relay?
Posted 12th Feb 2010 at 14:13
fletch
Track Head
Mine had similar symptoms with a dying crank sensor (on top of the gearbox).
Replaced it and it started instantly.
Posted 12th Feb 2010 at 14:19
dan_s16
The cam sensor is the blue sensor in the cylinder head.
The fuel relay is bolted to the back of the battery/ecu housing. It sometimes breaks off though so you may find the bracket there and the relay itself hanging down from the wiring loom.
Posted 12th Feb 2010 at 19:15
ar4ibaldo
Would not start on Friday or when it did.. would cut out.
Cleaned the TPS and now starts straight away.
Posted 15th Feb 2010 at 22:30
mabgti
NV motors
cleaned the tps? how so?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 15th Feb 2010 at 23:15
ar4ibaldo
The stepper motor.
Posted 16th Feb 2010 at 19:07
TPS and stepper are two different things Smile
Posted 17th Feb 2010 at 00:43
allesclar
fires on the first turn mate for me Dunno
sounds as if its being starved of fuel for the first turn.
Team allesclar ®
Posted 17th Feb 2010 at 00:48
ar4ibaldo
My bad, got the two mixed up.
It was the stepper that i cleaned.
Posted 17th Feb 2010 at 06:19
