Author Subject: Front Hub Torque
iplay
I want to get the correct torque setting. How can I tell which torque is for a phase 3 ... ?
Front Hub, M20, > VIN 808980
= 196 lb ft
Front Hub, M20, VIN 808980 >
= 181lb ft
Front Hub, M24
= 237lb ft
Thanks PhillipM for the torque settings Happy
Posted 16th Feb 2010 at 04:56
Vin being 32808980? Either before or after 328 Vins are around mid 1999 so your VIN should be after that so.
Guess the other difference is dependant on which ones have M24?
Posted 16th Feb 2010 at 05:41
f*cking tight, i thought i was trying the wrong way the first time i tried undoing 1 of these.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 16th Feb 2010 at 17:43
iplay
My Vin is after 32808980 but I am not sure which of the two torques is needed?
Posted 16th Feb 2010 at 19:35
afaik M20 is found on TU engines and MA boxes without ABS, M24 is on any BE box and MA/TU with ABS.
Servicebox says RP 08092 (January 4, 1999) not VIN, either way doesn't matter as they were M24 all the time on a 306 XU shaft.
Posted 16th Feb 2010 at 19:46
Should be M24 on yours Neil.
Posted 16th Feb 2010 at 20:16
pugjim
according to autodata its 320nm for a phase 3 gti6 M24
Posted 16th Feb 2010 at 23:48
tvrfan007
Holy crap, 320Nm for Phase 3's is that right?
That must apply to HDi too as the shaft is the same.
They don't seem that tight when you're undoing them!
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 28th Jan 2011 at 15:53
