displaying posts 26 to 50 of 87
Pages (4): 1 [2] 3 .. last
Author Subject: Ultimate Road/Track Rear Beam
pdd144c
Having the beam built for the road will always make it a compromise for trackwork. If you don't use it on the road that often I'd go for the following:
3 degrees of negative camber
25mm torsion bars
30mm ARB
Solid rear beam mounts
Bilstein Group N dampers
Full rebuild as needed.
Front wise, some more camber, Rich W lower arms and Bilstein Group N dampers with 5-700lb springs.
FOR SALE
205 Turbo Technics complete and 306 Rallye Race Build breaking.
Posted 20th Feb 2010 at 02:41
pinkfloyd
I run solid rear beam mounts, Spoox hybrid arb and Avo dampers at the rear (with lighter, wider wheels) and find it very good for track work however I am looking for some -camber for this season. Class regs do not allow me to use adjustable top mounts but Skip Brown do a mod to the front hubs to give 2 degrees- on the front. I would love some info on the modded trailing arms listed in this thread.
Liverpool Motor Club Sprint champion 2017
Longton & District Motor Club Sprint champion 2017
Liverpool Motor Club Sprint champion 2016
Liverpool Motor Club Sprint champion 2015
Lancashire & Cheshire Speed Championship
Winner 2014
2nd 2013
Winner 2012
2nd 2011
Winner 2010
Winner 2009
Winner 2008
Winner 2007
2nd 2006.
Posted 20th Feb 2010 at 02:48
So you weren't taken with the ASTs then Tom? What could be done to improve them?
Anybody mucking about with the rear toe at all? And yes lightweight 7" wide wheels are a must.
If I make it to the Essex RR day you lot are more than welcome to try my current setup and see what you think - would be very interested in some feedback.
Posted 20th Feb 2010 at 02:56
I've got a zero toe setup on mine, and whilst it does make the car a lot more adjustable on the throttle, and sharpens up the turn in, you do sacrifice some rear end grip and stability for it.
Somewhere halfway between would be ideal, I'm going to alter mine when I get chance.
Posted 20th Feb 2010 at 04:29
oops, tis Welshpug....
never felt my 0
Posted 20th Feb 2010 at 04:48
It's not so much unstable, just a little more nervous at the back on the high speed bends.
I really should stick some lightweight wheels on mine rather than these Mi16 alloys, given the rest of the weight savings LOL
Posted 20th Feb 2010 at 04:53
clen666
hmm such as.......?
Team 'unintentional rat look'
Posted 20th Feb 2010 at 06:34
Well, the tubular wishbones and 2-piece discs for a start Big grin
Posted 20th Feb 2010 at 08:38
Did you get my PM asking about how mine were coming along Phill?
Posted 20th Feb 2010 at 14:19
Post #35
vts_tibi wrote:
seems like I did really good with suspension mods yet as my present suspension od list is nearly the same
need a hybrid ARB from Ash, and AST topmounts
and perhaps some solid rear beam mounts Ninja
You know who to call for those...Whistle Wink
clen666
Post #36
oh yeah, forgot about those Doh
Posted 20th Feb 2010 at 15:11
davedgti6
Post #37
I have recently refurbed mine, and i have :-
New bearings seals etc,
21mm Torsion bars,
28mm Anti roll bar (with one trailing arm machined out to 30mm diameter to suit)
Lowered about 30-35mm although i'm thinking of raising it up another 10mm,
Standard pug dampers,
Solid skip brown beam mounts,
7" lightweight wheels on 15" 195/50 toyo r888's
Have to say i am pretty pleased with it so far, not tested on track as i have been skint but on the road it feels a lot more stable than before, on a couple of occasions i have had oversteer coming off roundabouts and a bit of four wheel drift,
I'm not sure on camber -maybe in the future and i may upgrade my dampers at some stage although seems fine at the moment and gives a nice ride,
Smile Dave..
Posted 20th Feb 2010 at 16:42
mxcrazy
Post #38
chris with a pug wrote:
Is that on an exchange basis?
Nope, send him your bare trailing arms and he will machine them and fit the oversize stub axles.
Posted 20th Feb 2010 at 17:47
Post #39
Sent you one back, PM system playing up again? Unsure
Posted 20th Feb 2010 at 17:51
Post #40
Could be my inbox, it's been full a few times of late (I just know someone is going to have something funny to say about that Roll eyes )
Posted 20th Feb 2010 at 18:00
Post #41
quote:
how much are the wishbones?
Are you sat down? Big grin
Posted 20th Feb 2010 at 18:39
clen666
Post #42
Argh stupid phone playing up messing my posts up.
Didnt think they would be cheap, but if my numbers come up tonight...!
Posted 20th Feb 2010 at 18:30
Post #43
Posted 20th Feb 2010 at 18:40
clen666
Post #44
Hmm, not as much as I was expecting tbh, I assume these would do away with the need for seperate wishbone bushes?
Posted 20th Feb 2010 at 20:51
Post #45
Yes, they're on rose joints on the inner mounts.
Posted 20th Feb 2010 at 20:52
clen666
Post #46
Tempting. I shall review my finances
Posted 20th Feb 2010 at 20:56
miles
Post #47
If your rebuilding the beam then you don;t need a Hybred ARB as the Arm pin's can take upto a 30mm bar, For road I'd go to around 27mm or Track 30mm
www.pugracing.com
Posted 21st Feb 2010 at 01:45
davedgti6
Post #48
miles wrote:
If your rebuilding the beam then you don;t need a Hybrid ARB as the Arm pin's can take up to a 30mm bar, For road I'd go to around 27mm or Track 30mm
I found that my standard pins where OK on one side to accept my 28mm ARB but on the other side i had to get it pressed out and machined to 30mm diameter, i then got the pin back in by leaving it in the freezer overnight, then mildly heating the trailing arm and then using BFH technology to tap/smack the pin back in, only cost me
Posted 21st Feb 2010 at 02:31
rallyestyle
Post #49
Thanks for all the replys guys, plenty of useful info Yes As i mentioned im going to stick with a fast road setup as i cant see myself getting on track more than twice a year and it will be my regular driver still Yes
I thought they were awesome, very stable and exactly the kind of comprimise i would be looking for. Only issue would be the price really,
Just Drive It
Posted 22nd Feb 2010 at 16:11
Post #50
Fair enough - I really liked CUJ's rallye on the B8s and eibachs. Was a very similar feel (from the passenger seat), but not quite as well damped.
And yes the price is a problem unless I break mine which is very tempting at the moment. Sad
Posted 25th Feb 2010 at 17:23
