displaying posts 51 to 73 of 73
Pages (3): 1 2 [3]
Author Subject: A bit disappointed!
stu
Post #51
smegal wrote:
I'll look into the boost ring but 27mm is ringing a bell, although I could well of dreamt that number.
The restrictor ring Rich supplied me with says 34mm, I didn't have one in the kit I bought.
Not sure if that helps but thought I would post it up anyway. Laugh
Posted 25th Feb 2010 at 02:40
chrisd306
Post #52
mine only runs 7 ish psi, but no complaints of power
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 25th Feb 2010 at 02:41
Post #53
smegal wrote:
They are the correct ones.
i mean what make, bosch eg??
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 25th Feb 2010 at 02:43
smegal
Post #54
Bosch (440cc)
Ex SC-6
Now in a Megane R26
Posted 25th Feb 2010 at 02:44
Post #55
qhat ford are they fitted to as standard?
Posted 25th Feb 2010 at 06:42
petert
Post #56
I wouldn't be disappointed. A Dynodynamics in shootout mode is about as reliable as it gets. However, forget the flywheel hp. You have 192hp at the wheels. This is the REAL figure that the machine measured. The operator then puts in a multiplication factor to arrive at the flywheel figure in order to keep pub talk happy. It's a shame the other graph isn't in wheel hp as well. Then you could reliably compare results. By my basic estimations, your 192hp ATW gives 250+hp at the flywheel.
Posted 25th Feb 2010 at 10:27
rallyestyle
Post #57
rich_w wrote:
The problem won't be the intercooler - plenty are using the Forge intercooler and getting 240-260 BHP which is the target power for the conversion.
My bad, just what farmer and i thought was stopping his car making around the same power as mine, all other components were almost the same.
Just Drive It
Posted 25th Feb 2010 at 15:43
rich_w
Post #58
Ford F-150 Lightning Supercharged truck thing Wink
Contact Details:
07732 822546
Posted 25th Feb 2010 at 18:23
rich_w
Post #59
A bigger intercooler will always be better for sure - but the low-boost conversion was developed with the Forge intercooler, and plenty of cars have made 250-260 BHP with it, so I don't think it the main reason this car is under-performing.
Smile
Contact Details:
07732 822546
Posted 25th Feb 2010 at 18:30
Post #60
hmm, is that the one that uses the same engine as the gt thing??
Posted 25th Feb 2010 at 18:26
allesclar
Post #61
rich_w wrote:
I bigger intercooler will always be better for sure - but the low-boost conversion was developed with the Forge intercooler, and plenty of cars have made 250-260 BHP with it, so I don't think it the main reason this car is under-performing.
Smile
So by keeping the same intercooler and uprating everything else like you would on high boost, you can still hit over 260bhp hint hint? Smile
Team allesclar ®
rich_w
Post #62
I think the wheel / flywheel power is correct
Contact Details:
07732 822546
Posted 25th Feb 2010 at 18:50
rich_w
Post #63
allesclar wrote:
Smile
Yes
Contact Details:
07732 822546
Posted 25th Feb 2010 at 18:56
rich_w
Post #64
Another thing to bear in mind
Contact Details:
07732 822546
Posted 25th Feb 2010 at 18:59
smegal
Post #65
It went on the rollers again [at skip browns this time] and they said that the mapping was untidy at part throttle and could be tidied up.
The bigger ring made the fuelling lean out but didn't really add a noticeable power gain so it went back off.
Ex SC-6
Now in a Megane R26
Posted 11th Mar 2010 at 21:42
robthe6
Post #66
rich_w wrote:
If you
1997 ph1 bianca GTI6 - The looker
1996 ph1 Sigma GTI6 - Dead Sad
1999 Red Rallye - The Daily
2005 Nissan Navara D40 - Family car
1968 Mustang Coupe - The dirty little secret
Put ya foot down, put ya foot down we'll loose em easy!
Posted 12th Mar 2010 at 01:32
mabgti
NV motors
Post #67
craig... get the compression test done.. get diagnostics run on all sensors.. then concentrate on timing and then look at the map. As these maps accomodate alot of variations hence why there is no real need for a custom map!
when did you go skip browns? printout?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 12th Mar 2010 at 03:41
allesclar
Post #68
in fairness too craig, your car was idling around 800 rpm, thats seems a tad bit low Dunno
Team allesclar ®
Posted 12th Mar 2010 at 03:43
smegal
Post #69
I really can't see it losing compression since the last test, it was compression tested before it had a top end rebuild. As for sensors, the Lambda, CTS and ICV are all new genuine replacements. I will look at the Map sensor and the TPS though. Also it ran and idled perfectly before the boost so the sensors should still be fine.
It was more of a diagnostics than a power run, I was seeing if it was worth fitting the restricter with a 4% bigger hole in it. The operator was holding it at varying revs and monitoring the AFR, this is why he mentioned the map issues at low throttle openings.
As said above the mixture become a little lean with the larger ring in it and I reverted back to the smaller one to reduce damage. On the run there was no smoke and it hasn't used any oil in the 1500 miles it's done so far.
I think the next thing will be a trip to chipwizards for a look at the timing.
If that shows nothing up then a compression test will be looked at.
Ex SC-6
Now in a Megane R26
Posted 12th Mar 2010 at 06:19
mabgti
NV motors
Post #70
What was the point in that? partial throttle afrs arent any use to diagnose your issue. In all honesty this sc setup will not be perfect as say a pos boost setup usimg a standalone ecu.
A timing check wont take long.. although id use a scope and a dial gauge Smile
Let me know when you book with wayne as i need a power runYes
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 12th Mar 2010 at 11:52
rich_w
Post #71
The map issues at low throttle openings are more likely to be lambda related than ECU software related.
The ECU runs in closed loop at throttle angles less than 70% so will be constantly trimming the fuelling.
You should have just taken it to Cchipwizards in the first place - taking it to someone that knows nothing about the conversion isn't going to help a lot.
Contact Details:
07732 822546
Posted 12th Mar 2010 at 23:05
smegal
Post #72
It will be going to chipwizards when I have the money. This was as an exercise to make sure that the new boost ring wouldn't make it run lean [which it did].
Ex SC-6
Now in a Megane R26
Posted 13th Mar 2010 at 05:26
paul_gti6
Post #73
That told you Smegal Smile
Posted 12th Mar 2010 at 23:51
Pages (3): 1 2 [3]
