Author Subject: sc'd s16
razzario
Anyone done it? will the standard lynx gear fit?
I'm considering it as an option for some bonkersness in the near future LOL
Posted 24th Feb 2010 at 18:42
I'm not sure if anyone has done it, or if it does fit, but I'm pretty much sure it will fit.
Posted 24th Feb 2010 at 18:43
razzario
i've e-mailed lynx a few questions
Posted 24th Feb 2010 at 18:47
birk
Well the inlet from the gti6 fits the s16, so dont see why not.
Not so sure on the ancillaries bracket though.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 24th Feb 2010 at 19:06
dan_s16
I've thought about doing it to mine but can't afford it.
Although the engine mounts are different shapes the Gti 6 mount fits the S16 block so I can't see that being an issue.
Infact I think your main problem will be the exhaust manifold. I just think it will be too restrictive.
If you do go ahead with it though keep us updated as i'd like to see how it goes.
Posted 24th Feb 2010 at 22:28
cosmic spanner
Moral objector
.. and the ECU would be a fair bit of work, I'd have thought? Unless you go to the GTI6 ECU (and relevant sensors, if they're different) & generic map.. or go aftermarket ECU.. Unsure
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 24th Feb 2010 at 22:35
mabgti
NV motors
s16 will work in terms of kit fitYes
but ecu as cosmic says will be tricky. No one has maapped a s16 ecu for boost that i know of plus s16 has internal map sensor so throttle body mounting will be different. Rich is your man.. or contact wayne schoffiel at chipwizards..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 24th Feb 2010 at 22:36
I have a maniflow exhaust manifold that will fit an s16 Smile could maybe part with it for the right money
Posted 24th Feb 2010 at 23:24
soton_s16
bigbadbowen wrote:
I have a maniflow exhaust that will fit an s16 Smile could maybe part with it for the right money
Does it include the manifold?
For all your Peugeot needs PugRacing.com
Gti S16 199bhp 164 ft lbs torques!
Posted 24th Feb 2010 at 22:42
Sorry I meant the manifold not the exhaust - my bad
Posted 24th Feb 2010 at 23:23
razzario
i have an omex 600 here from another project i could use, but having had a quick search i don't see why the gti6 ecu wouldn't go on there along with all its sensors and wiring (and it frees the omex up for the other car)
Posted 25th Feb 2010 at 00:06
allanallen
Doesn't the s16 use the same basic ecu as the xu10 8v turbo engine? I'm sure wayne can re-map those.
Facebook
Posted 25th Feb 2010 at 01:28
soton_s16
Does it fit a 306 S16, or is it for a 205 conversion? If so, what sort of price are you thinking? Ninja Smile
Posted 25th Feb 2010 at 02:02
I had it on my MI engine in a 306 I Believe the mi and s16 have the same stud layout ???
will think about the price, cost a lot as its the 3 part racing manifold with 2 ½ inch bore maybe get a pic up ?
Posted 25th Feb 2010 at 04:03
