Seems to drive ok did 10 miles at 20mph and all the balljoint bangs and stull have gone and everything is tight,
TRE is still tight to the nut so that hasn't moved
Got to get from leeds to doncaster first thing in morning
| Author | Subject: Urgent help with wierd clunking and grinding |
kezman7
Senior User Location: Castleford Registered: 20 Feb 2009 Posts: 762 Status: Offline |
Just fitted my new hub and now when driving theres a very loud clunking and abit of grinding. Seems to be the bottom mount moving to one side when the shaft is turning. Got mot in morning and its only just started. Also very bad pulling to the left. Noticed the Tracking was out at the RR but it was no where near like this! Seems to drive ok did 10 miles at 20mph and all the balljoint bangs and stull have gone and everything is tight, TRE is still tight to the nut so that hasn't moved Got to get from leeds to doncaster first thing in morning |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
Sounds like a front spring might have snapped? |
jon kirby
Seasoned Pro Location: pothole central Registered: 14 Jan 2004 Posts: 7,008 Status: Offline |
is the right size ball joint in the hub? hubs vary between 16 & 18mm ball joints? |
fletch
Track Head Location: The nearest Shell garage Registered: 12 Jun 2004 Posts: 12,273 Status: Offline |
jon kirby wrote: is the right size ball joint in the hub? hubs vary between 16 & 18mm ball joints? Seconded, sounds like something daft like that. |
kezman7
No thats why i changed the hub as i fitted a 18mm balljoint into a 16mm hole before to get it driviable. No knocks from suspension now but i was underneath when the engine was started and you can see the bottom mount moving the engine to the right when the shaft turns |
knackered driveshaft I'd guess.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fletch
Are the hockey sticks done up correctly on the bottom mount?Engine mounts all ok? With the tracking, did you do up the TRE to the same position it was before removal? |
