Author Subject: :uhoh. Headgasket??? Help!
cahillscornerflag
Hi guys. Ok, first mega problem with the 6 in 3 years of ownership.
I was driving home yesterday when i got stuck in some traffic, after sitting in this traffic for something like 3 minutes i noticed my temp guage was reading 90, i thought this was odd as i'd just started her up to start my journey and been driving for only 5-10 minutes.
About another minute later whilst still in this traffic i watched my temp guage move quite quickly all the way over past the red, bringing on my STOP light. I put my blowers on to let some heat out, and got nothing but cold air.
I pulled over, stopped the engine and opened the bonnet, Both my fans were spinning and the inlet manifold was freezing but the engine was red hot. I got a massive rag out the boot and slowly opened the water cap, and dirty brown water went everywhere, there was so much pressure it was unreal. I Checked the dipstick and the oil looked really thin, but not milky. On the short journey back home (at 20 mph in 6th, crapping my pants) engine sounded awful and felt down on power.
Can anybody confirm the worst, is this HG failure? Do they just go like this? There wasn't any white smoke or anything and she'd been running like a dream prior to this.
Help! Sad
'00 Astor Grey GTi-6 - Regretfully sold!
'89 Onyx Black 205 GTi 1.6
Posted 5th Mar 2010 at 14:59
mechanical_repairs
They do just tend to give no real signs and then just let you have it like you describe, firstly i would refill the cooling system and restart the car from cold with the rad cap removed, if you can see alot of air circulating around it it will be a 90% chance the gasket has failed and it's putting pressure into the cooling system, normally you tend to get a misfire on initial start up and after a rev will clear, this is due to one of the cylinders having coolant in there and after starting it gets burnt and then starts to operate.
Carl
Posted 5th Mar 2010 at 15:02
Get a compression tester and try that first - also check to see if the plugs are a different colour.
Not a great idea to open a pressurised and hot coolant system Doh
Posted 5th Mar 2010 at 15:03
cahillscornerflag
Carl
Carl,
Forgot to mention, i've been getting a slight misfire on start up, i just put this down to the new plugs i'd fitted, and one of them maybe being lose.
B*llocks, I think the writings on the wall...Sad
How could i get it up to you mate? I've got the AA with pretty much everything, would they trailor it upto you?
Posted 5th Mar 2010 at 15:08
If you're lucky it will be limited to pressurising the cooling system and not mixed with the oil.
its just an XU engine though, anyone can fix them Smile
Posted 5th Mar 2010 at 15:13
cahillscornerflag
True. If it has mixed in with the oil, I presume there will be damage internally? It's been driven approx 3 miles since.
Posted 5th Mar 2010 at 15:21
If it has mixed you would have potentially damaged the bearings, which is why many engines start knocking so soon after a headgasket Doh
Mine was doing the misfire on startup for some time but didn't mix with the oil till the gasket went properly, luckily caught it in time, I have taken the sump off and the bearings are still in good condition.
Posted 5th Mar 2010 at 15:40
smegal
Make sure that your AA cover has 'relay' IIRC then drive it more than ¼ miles from home and call them saying that the stop light has come on and the temp is in the red etc etc. When they come out and diagnose the headgasket tell them that you trust a garage in leicester and give them the address.
Ex SC-6
Now in a Megane R26
Posted 5th Mar 2010 at 15:45
Peugeot trained mechanic not far from Surrey
Posted 5th Mar 2010 at 15:53
cahillscornerflag
Ok, thanks for the replies fellas. Just phoned a main stealer, and they want
Posted 5th Mar 2010 at 15:58
cahillscornerflag
Ah yes, forgot about Deepak! I shall get onto him too.
Posted 5th Mar 2010 at 15:59
mechanical_repairs
Carl
Carl,
Yes just ring them up and get them to drop it here, come with it if you like and i will give you the courtesy car, otherwise get it up here and come over the following day and i will have it fixed.
Carl
Posted 5th Mar 2010 at 16:49
gti-dan
My water temp creeps up a fair bit when im stuck in traffic for too long but its never been long enough for a stop light to come on, ive managed to get moving and air over the rad in time.
It has survived Oulton Park and over 1000 miles of driving since i noticed it (ive only had it about 1000 miles so i dont know about before that)
Could my head gasket be going??? Most older cars i've had - their temp has crept up whilst stationary???
Posted 6th Mar 2010 at 17:05
more likely to be a poorly rad.
though the temperature the fans actually come on at is a fair amount higher than the temperature they sit at whilst on the move, as long as the fans can maintain the temperature and it doesn't keep on rising its fine.
Posted 6th Mar 2010 at 17:38
