Author Subject: Remote filter Kits
kezman7
Seen these, Would it be possible to do the same on a 306? Using a 306 sandwich plate just instead of the ford ones in the kit?
Not sure about the filters you could just use the ford ones maybe? Althought a proper 306 filter mount part would be better?
Anyone doe this or discussed it?
clicky
Posted 6th Mar 2010 at 04:52
mabgti
NV motors
so you want to increase the chance of an oil leak and possible pressure fail... just to put the filter in a place you dont have struggle with if your a fat bas**rd! why?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 6th Mar 2010 at 05:09
kezman7
Im not overly fussed atm but i need to fit a fan to the rear of the rad so its unbelievably tight in that area now.
Posted 6th Mar 2010 at 05:10
kezman7
Was flicking thought ebay and caught my eye and wondered why uv not seen it before on our cars
Posted 6th Mar 2010 at 05:11
smegal
Surely it's no more risky than an oil cooler?
Ex SC-6
Now in a Megane R26
Posted 6th Mar 2010 at 05:15
mabgti
NV motors
just use a smaller filter... one from lesser powered XU engine will do and still filtrate well.
oil pressure from cold on a 6 is bout 20psi iirc? stick the oil filter a metre away from block and turn upside down and see how much oil you get there...
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 6th Mar 2010 at 05:18
I would've thought that cold oil would be thicker, and the oil pressure would therefore be higher on startup, then get lower as the engine heats up.
I agree with what you say about the pressure drop through the hoses though.
Posted 6th Mar 2010 at 05:50
allesclar
but why would it matter? surely the oil has to go through the filter at some point as its in a loop?
Team allesclar ®
Posted 6th Mar 2010 at 06:16
matt306gti
I understand where your coming from about the increased chances of an oil leak as there is more plumbing.. but pressure failure too?
I cant see it.. all you need to do is calculate the extra capicity of the route the oil will have to take to reach the filter and increase the amount accordingly, therefore a drop in pressure should not occur.
A freind of mine had a kit simmilar to this on his 200sx, he used to take part in drift and track days almost every weekend so oil changes were far more frequent. He never once had any problems regarding leaks or pressure loss, the kit really added a professional look to his engine bay too.
If your serious about getting one of these then forget ebay and take a look at Demon Tweeks mate, they sell the Mocal Oil Cooler and Relocation kits (same one my mate had) and they are top quality for a reasonable price Smile
Posted 6th Mar 2010 at 09:21
