Author Subject: Rocker Breather pipes
mark-house
Just a quick question. What effect would it have on the running of the enigne if the two breather hoses on the top right hand side of the rocker were blocked?
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 8th Mar 2010 at 17:55
It'd probably blow the dipstick out of the tube.
Posted 8th Mar 2010 at 17:58
jeffers Forum Admin
Almost definately! Yes
Team Running Engine again!
Team Negative Camber!
Posted 8th Mar 2010 at 18:13
mark-house
Cool that would be fun to see! what about if there was a partial blockage? could it cause idle/rev faults similar to those from a failing MAP/ICV?
Peugeot 306 GTi 6
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 9th Mar 2010 at 00:01
matt306gti
Highly likely..
The rocker breather system is there to do 2 jobs. Remove oil and water from the hot air at the top of the head and secondly to relieve positive crankcase air pressure iirc Smile It also stops backfires into the inlet manifold from igniting crank case gasses, which you really dont want happening!
By pulling these gasses from the crankcase it will also prolong the life of your engine oil, which is a nice little bonus Smile
On idle it basically sucks the bad vapours out of the engine so if it is partially blocked it will almost definately be causing issues. Scrap the old pipes and stick a catch tank on there, make sure you plumb it in properly though, many people opt to plug the pipe on the inlet mani but this is actually wrong Whistle
Posted 9th Mar 2010 at 07:24
chris with a pug
matt306gti wrote:
Highly likely..
Explain please
Posted 9th Mar 2010 at 14:27
eddy_gti6
fit an oil catck tank from the pipe that comes from the Rocker cover to the throttle bodie
Posted 9th Mar 2010 at 14:36
mark-house
Nice one Cheers Chaps
Peugeot 306 GTi 6
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 9th Mar 2010 at 17:36
chris with a pug wrote:
matt306gti wrote:
Highly likely..
Explain please
If you are fitting a catch can you still need the pipe to inlet connected,as it 'sucks' out the gasses etc from crank caseWink
Otherwise you are just relying on the 'blow by' pressure passed piston rings to push gasses etc out,which on a NASP engine isn't alotSmile
A proper catch can/breather tank set up will be filtered inside,to seperate fluids(oil/condensation) from gasses before it gets sucked into inletWink
These are proper catch cans that work:
http://www.saikoumichi.com/OCC_explanation.htm
Smile
Posted 10th Mar 2010 at 02:36
allesclar
clicky for the thicky
Team allesclar ®
Posted 10th Mar 2010 at 02:39
allesclar wrote:
Ha ha Flip
How do you put up a clicky on this forum by the way??????Whistle
Posted 10th Mar 2010 at 02:42
you have to manually do the [url= stuff
Posted 10th Mar 2010 at 02:47
Ok,ta MeiWink
Means nowt to me I'm afraid..............Whistle
Posted 10th Mar 2010 at 02:50
