Author Subject: 2.1 Crank
kezman7
Reading about the Diesel crank and that would need custom pistons 1mm shorter to accomedate the longer travel.
Possibly the most stupid question ever but would it not be possible to use a thicker head-gasket to give just the right amount needed?
Posted 11th Mar 2010 at 05:50
you'd need 4mm for a 2.1 crank.
so no a thicker gasket wont help.
Posted 11th Mar 2010 at 16:27
bobdylan_55
gti6 stroke is 86mm, 2.1 is 92mm, so 6mm total, 3mm either way, so you would need to find 3mm not 1.
if you used it on a 1.9 block though with 83mm pistons which run 88mm stroke, then its 4mm difference in total, or 2mm either side. 2mm could be acheived by having a small amount of material removed from the top of piston and a small head skim, and a repair gasket.
but then its 83x92 which is only going to give 1991cc, so you would get more out of a standard 2.0 (1998cc)
309 GTi6-T
Posted 11th Mar 2010 at 17:01
ryangti6
I would assume reading the original post he meant an 88mm stroke diesel crank in place of the 86mm to send him up towards a 2.1 bottom end. It would make sense then anyway.
Kezman, have a look on 205drivers, there are a good couple of threads detailing swapping cranks etc and what can be swapped with what.
Depending on what crank you do mean then I think you could possibly use s16 rods as they are ~5mm shorter than the gti6 ones iirc
Ryan
Posted 11th Mar 2010 at 17:12
arrr maths fail in my post Laugh my ass off
I see what you mean Ryan, you can do this to an Mi/S16 iron block bottom end as the pistons are flat topped and sit 0.7mm under deck level.
you also have quite a lot more space in an RFY engine as the chamber in th ehad is a tad bigger and they have pretty hefty valve cutours compared with the RFS
S16 rods are 152mm, gti6 are 158mm, bit too much difference there Doh
Posted 11th Mar 2010 at 17:21
bobdylan_55
the rod length wont matter because the pistons are different hieghts, works out that the s16 pistons and rods are 1mm shorter in total.
as for the 88mm crank, didnt think of that lol
86x88 = 2045cc
309 GTi6-T
Posted 12th Mar 2010 at 03:36
kezman7
Hmm so its not as straight forward as i was thinking/hoping. Might get in touch with carl or rich see what they think/can do. Is it really a worthwhile mod?
Posted 17th Mar 2010 at 04:21
What are your plans?
Posted 17th Mar 2010 at 04:22
depends if you're going n/a or supercharged, no point really if you're going S/C.
Posted 17th Mar 2010 at 04:44
kezman7
I was wanting abit more power but to keep the engine N/A but i think iv overrated it or got the info iv read up on wrong.
Posted 17th Mar 2010 at 04:45
mxcrazy
Get some 87 or 88mm pistons made, i can supply you drawings for 88mm pistons that will work with the 1.9td 88mm crank and stock GTi rods to give you 2139cc, not only are you increasing displacement, but with my particular pistons compression also, it also give you more scope to have the combustion chamber modified, mainly to un-shroud the valves to improve low lift flow. Plus i have huge cut outs to run 'big' cams if need be.
Alternatively get some off the shelf pistons, oversize, and get some rods made, think you can have them made for about
Posted 17th Mar 2010 at 14:51
It never stops...
Posted 17th Mar 2010 at 16:23
Suddenly my 2940cc looks cheap if lower powered...
Posted 17th Mar 2010 at 16:59
mxcrazy
......and sounds gorgeous no doubt.
Theres some euro guys running like 98 or 100mm stroke, 88mm bore xu10's. Farndon engineering make the cranks i believe,
3 x Peugeot 306 86mm stroke EN40B Crankshaft (with opel B.E)
Thats what they are showing as stock, only 86mm bore but i bet that would be a lovely piece of kit, especially for a 9000+ rpm motor.
Id love a huge bore/stroke 4 pot engine though, 2.4 litre or something.
Posted 17th Mar 2010 at 17:05
2.3 Mi16 on youtube ignore the graphic, it is 2299cc, circa 270 bhp, epic torque.
dyno results thread
XU13J4 build thread
Posted 17th Mar 2010 at 17:20
jamesta
Here u go mate...
simple... and if i'm not wrong you can do it with the engine still in the bay working underneath
Peugeot Sport chip...Upper motor mount mod...Å.Ì.Ò.Ñ. Racing Steering Wheel...Brembo MAX+EBC pads all around...De-cat...GE Quickshift...
Street Racing Style Front Bumper (not installed yet)...Street Racing Style Rear Bumper (not installed yet)...Street Racing Style Side Skirts (not installed yet)...Laguna splitter (not installed yet)
Ouragan 16" 6,5J (not installed yet)...
more are comin' in the future Smile
custom made lower strut brace on the way......
Posted 18th Mar 2010 at 04:48
