Author Subject: pugracing
ken
anyone fitted this?
i have had one for a month or 2 now and will be fitting it soon, just need some advice really as i havent seen one like this lol
and im confused :S Big grin lol
cheers
Team Black Rallye Big grin
xbox live - Xx 7 kenny 7 xX
Posted 16th Mar 2010 at 04:15
fitted what ????
Posted 16th Mar 2010 at 04:19
ken
lol oh yeah the quickshift??
Posted 16th Mar 2010 at 04:47
pugheaven
There is a thread about the quickshift, its a pain, the lower top hat bush hits the inside of the quick shift when trying to get into 1st 2nd 5th reverse or sixth gear i had to make my own top hat bush so you get more clearance and can get into every gear with out hitting the inside of the mount.
Posted 16th Mar 2010 at 13:09
ken
ah right! hmmm may have to look into it lol!
cheers
Posted 16th Mar 2010 at 16:02
top hat bush probably perfectly fine unless you try and make the shift too short LOL
Posted 16th Mar 2010 at 17:01
pugheaven
No thats without a the gear shaft in the top hats so it doesnt matter what throw you have it set at if that makes sense.
Posted 16th Mar 2010 at 20:13
err, not really LOL
Posted 16th Mar 2010 at 20:18
ken
:? lol
Posted 16th Mar 2010 at 21:10
pugheaven
If you have more lever in side the car it makes it a long throw, less inside the car makes it a short throw but the pivot point stays the same. So if you have it set at long throw and its say 45 degrees to get it into gear, the bottom part of the shaft (under the car) is also at 45 degrees, the top hat is fine inside the car but the other one will foul on the inside of the cast. If you shorten the throw so the lower top hat doesnt hit you will end up with about 5 degrees inside the car which is way to short, as in you can hardly feel it move. Iv done it and so has some one else and mine works sweet now.
Posted 16th Mar 2010 at 22:09
ken
ah right i sorta understnad mate.
will have ago once my shift is over.
cheers
Posted 17th Mar 2010 at 00:41
pugheaven
its a b*tch to do so i wouldn start doin it if you need the car tomoro. Its a two person job really.
Posted 17th Mar 2010 at 02:35
ken
lol, what would you reckon is better then? the ge? this one? or b&m??
my car is off the road at the moment so can do it whenever really
Posted 17th Mar 2010 at 02:37
