Author Subject: Adjusting Doors
iplay
The title should read Adjusting doors when slightly feck faced!
How the feck do I adjust the doors without removing the front wing?
Posted 21st Mar 2010 at 22:08
Big hammer.
Posted 21st Mar 2010 at 22:09
iplay
phillipm wrote:
Big hammer.
that is about as much help as my wife who said 'i told you so! referring to the big sign which she wrote in the garage saying no car work before dark! Roll eyes
Posted 21st Mar 2010 at 22:51
iplay
Ok so this morning I have to use the passenger door to enter/exit! Clearly out of my depth so nothing new there.
can anyone tell me the correct way to get the door aligned and the hinges true (so the door opens and closes smoothly)?
Do I need to take the front wing off and adjust the hinges with the door in a closed position? or can it be done with the door open? seems a bit hit and miss and then to get the hinges aligned seems even harder!
Posted 22nd Mar 2010 at 16:08
CUJ
What have you done to the door?!
Mech Repairs adjusted mine as it wasn't aligned; he just opened the door and applied his weight to the frame, bending it back down LOL
340 horses
Posted 22nd Mar 2010 at 22:22
sixygti2
Work out how it needs to be adjusted first. Whip the door off and adjust hinges to suit, re attach door and voila!!
Think thats how I did mine anyway Unsure
Still watching you...
Posted 23rd Mar 2010 at 05:05
jimbobewob
thats what i done. Thumbs up
Posted 28th Mar 2010 at 02:30
iplay
I don't see how you can adjust the hinges to the correct position without having the door on?
Is it possible to adjust the hinges from behind if the front wheel arch liner is taken out?
Posted 2nd Apr 2010 at 02:04
rich-6
This! What people dont realise Doors Tailgates etc have to be given a bif of persuasion now and then to fit right Ninja
Cool
RIP Pete Sims
Posted 2nd Apr 2010 at 05:10
sixygti2
Well as i said, before removing the door, you need to check how the door is sitting. From that you can guess how the hinges need adjusting, then take the door off...
With my door, it was dropping slightly, so the top corner of the door was scrapping against the rear framework, so it needed lifting. All i did was remove the door, loosen the top hinge and move it further towards the front of the car, re-tighten, and this would mean it would pull the door to the correct position, and now it sits fine and doesn't rub!
Hope that makes sense Thumbs up
Posted 2nd Apr 2010 at 19:50
jord294
so your saying that the actual part of the hinge that bolts to chassis, has elongated holes to slide hinge either backwards or forwards
Huh?
Posted 28th Dec 2010 at 19:12
smegal
If it isn't that far out bending it is actually the easiest way of getting it spot on.
Ex SC-6
Now in a Megane R26
Posted 28th Dec 2010 at 22:58
sixygti2
Huh?
Cant remember if they were elongated, but there was enough movement to adjust and suit my needs! Wink
Posted 28th Dec 2010 at 23:37
davidmartin
Thats the way to do it,remove wheel and arch liner,close the door then loosen the bolts through the arch holding the hindges, then line up the door and retighten the bolts.If you cant get a good fit you can then loosen the bolts holding the hinges on the door for aditional adjustment. I new those 9 days in bed reading the haynes manual would come in handy at some pointLOL
pet hate, the cat
Posted 29th Dec 2010 at 00:47
russbez
anyone else done the above?
my doors have been off and i dont think they are lined up straight
My Rallye project thread
Posted 26th Mar 2012 at 11:06
smegal
If they aren't far out, strategically applied force really is the easiest way. Adjusting hinges is a pig.
Ex SC-6
Now in a Megane R26
Posted 26th Mar 2012 at 11:14
russbez
i think iv already made a balls of adjusting the hinges via the 4 No. 13mm bolts.
Bending them seems a bit permanent if i f**k it up LOL
Posted 26th Mar 2012 at 11:16
smegal
Bend em back. It does depends on how bad we are talking. banding is a minor adjustment method only really.
Ex SC-6
Now in a Megane R26
Posted 26th Mar 2012 at 11:23
