Author Subject: Another Stalling/odd idle thread!
honestly3k
Hey all, have searched a little through the forum but thought i would just get a more case specific answer from some of you.
So my car has over the last two weeks has had problems with stalling, it started off just when i pressed on the brake when coming upto junctions, dipping the clutch and breaking would cause the engine to cut out....pretty embarrassing!
Now when i brake to a stop if it doesnt stall it will sit and i can feel the car pulsing with a vibration from the engine (when idle), now when i go to drive off again the engine will cut out if i even brush the throttle pedal.
Car also struggles to start on occasion.
Now ive only on saturday had a new lambda and cat on the car to get it through the MOT. Ive read through some threads on here and decided it could be the Map sensor, Idle control valve etc etc...just wondered if anyone could point me to the most likely culprit...?
And also how much i can expect a replacement part to set me back and if poss where i can find it on the engine so i know where to look when replacing it myself, as i really cant afford to put it in a garage at the moment!
Ive heard its simple enough...?
I also heard if this problem is left it only gets worse untill the car completely refuses to start?
Any info appreciated thanks!
Posted 24th Mar 2010 at 01:51
honestly3k
Engine is the 1.8 16v one.
kit
I'm popping into Peugeot in Aylesbury on Thursday if you want to meet me mate. I won't be able to do much but to listen and look at the symptoms though as I am no mechanic LOL you can see if they will quickly hook it up to a diagnostics machine for you.
It sounds like the ICV to me. Take it out and give it a clean with some carb cleaner and see if that solves the problem, if not, then try replacing it. It could also be the MAP. I had the same issues as you do and cleaned the ICV and replaced the MAP. In the end I replaced the ICV too which cured it (although it still stalls once in a blue moon).
IIRC I got a genuine ICV from Carl for about 70-80 quid.
If it sometimes doesn't start that could be down to a dirty/knackered crank sensor.
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 24th Mar 2010 at 03:02
honestly3k
Christ, im really not happy at the mo!
Ive just been arse raped from a garage in aylesbury to the tune of
Posted 24th Mar 2010 at 18:44
honestly3k
[IMG]http://i956.photobucket.com/albums/ae44/honestly3k_2009/My%20freaking%20car/24032010145.jpg[IMG]
Is that little brown thing my ICV - is it meant to split into two parts and should i do this while cleaning it?
Also wondered if anyone knew where this pipe from the radiator cap shaft is supposed to go as i noticed its unclipped from the other end?
[IMG]http://i956.photobucket.com/albums/ae44/honestly3k_2009/My%20freaking%20car/24032010146.jpg[IMG]
Thanks again
Posted 24th Mar 2010 at 19:26
honestly3k
blah!
honestly3k
Posted 24th Mar 2010 at 19:27
honestly3k
Bump for a quick answer?! Smile
Posted 24th Mar 2010 at 19:36
kit
No mate, not sure what that is on the top of my head. Let me find a pic of the ICV for you.
*EDIT*On a GTi6 engine it's located near the MAP. (bad picture, I have a much better one at home I will post up).
I'm not sure if it will be located in the same place on a 1.8?
Posted 24th Mar 2010 at 19:53
honestly3k
Cheers for that will go an investigate again, if you could get that pic up later it may help, guna head to town now for a bit!
Cheers again Smile
Posted 24th Mar 2010 at 19:54
kit
Here is a better view of the engine bay.
Posted 24th Mar 2010 at 23:45
honestly3k
Interesting hehe!
Ther are a load of things that look similar in that sort of area, will just have to try figure it out tomorrow.
Any idea about that pipe coming from the Rad cap shaft??? Its bone dry so dont think its been carrying anything recently...
thanks Wink
Posted 25th Mar 2010 at 00:27
greenbelt
thanks Wink
It's the overflow pipe. If you have too much coolant in the radiator it will release the excess Smile
Standard Black 6
Black HBSC6 Smoke
Posted 25th Mar 2010 at 01:41
honestly3k
Ah, genius! thanks Wink
Posted 25th Mar 2010 at 01:46
vincemasi
the pipe coming from the pipe is an overflow pipe is ment to be like that. if you put too much coolant in ur rad once your engine gets hot and the system increases in pressue it will realise the exta coolant from there to protect the radiator and other components.
as to the idle problem GSF doesnt do the stepper motor last time i checked but does do the MAP sensor for about
Posted 25th Mar 2010 at 01:55
jcphat
The ICV is very close to the throttle body- You find that as it is controlled by the accelerator cable. If you look at the rubber air hose from the air filter to the throttle body you will find a small branch hose which is about thumb thick- that goes into the ICV. The brown jobbie is to do with petrol fumes and emissions and not at all to do with your problem. Please do not go to main dealers with a 10 year old car unless you wish them to strip your wallet bare. Their labour rates are twice that of ant local garage at least. They should not charge you that kind of money but they do because they do not care and do not want to look after old cars.
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 25th Mar 2010 at 01:52
honestly3k
Thankyou guys. Some great advice. Just identifying the thing might take some time as im not that good with engines...
vincemasi
This will show you how to reset ecu
http://www.306gti6.com/forum/showthread.php?id=16861&page=last
Posted 25th Mar 2010 at 02:02
vincemasi
Here is the guides on how to test the Sensors. you dont need to test the lambda sensor as you said its new.
http://www.306gti6.com/forum/showthread.php?id=80340&page=1
Posted 25th Mar 2010 at 02:06
vincemasi
As to you not knowing what sensors look like if you look on ebay and google images you will find pictures of the sensor so when you take the car apart you know what yuo looking at.
Posted 25th Mar 2010 at 02:07
kit
Like I said mate, if you are struggling to locate the ICV I am at Pug picking up a filter tomorrow. I'll have a look for you Yes
Posted 25th Mar 2010 at 02:11
honestly3k
Thats great, thanks. This site has always been much more helpful than the pug306.net one.
Thanks Kit, what time are you heading down there?
Ive got work most of the day but i think i should be finished around 3ish or so, i take it you mean the perrys peugeot along the tring road?
Posted 25th Mar 2010 at 02:20
kit
Yes Perry's just before the Aston Clinton Bypass. I'm going down there on my lunch break at about 1.30/2pm if you can make that? If not take a picture of your entire engine bay and post it up.
Posted 25th Mar 2010 at 02:26
honestly3k
No chance of me getting back in time i dont think. Got a job at 12 in Hatfield, will take a couple of hours then an hour drive home.
No worries, will post up a photo if im really stuck! Smile
Posted 25th Mar 2010 at 02:29
