they done it 3 times to try get it corrected but the garage believed something else might be causing it to pull, what other things could be causing it?
cheers
| Author | Subject: pulling to the right |
craigy_87
Seasoned Pro Location: wishaw Registered: 06 Jan 2008 Posts: 1,325 Status: Offline |
i've just had the wheel alignment done on the car but although its a million times better now, it still seems to pull slightly to the right.they done it 3 times to try get it corrected but the garage believed something else might be causing it to pull, what other things could be causing it? cheers |
what condition are the suspension bits in?A mate had this on his car and in the end a set of new tyres sorted it out |
craigy_87
its had new track rod ends second hand wishbones but with the new P bushes and ball joints i think one of the shocks may be dying (slight leak) though would this cause it |
craigy_87 wrote: its had new track rod ends second hand wishbones but with the P bushes and ball joints i think one of the shocks may be dying (slight leak) though would this cause it Maybe,havent got a snapped spring perhaps? |
craigy_87
hmmm i cant see it snapped anywhere but i'd need to look againsurely they would see that though when looking over it today |
craigy_87 wrote: its had new track rod ends second hand wishbones but with the P bushes and ball joints i think one of the shocks may be dying (slight leak) though would this cause it Snapped spring perhaps? |
hbinky
Newbie Location: Wem Registered: 22 Jun 2009 Posts: 36 Status: Offline |
I had a snow tyre on my old diesel which was the cause of my car pulling widly to the right, only found out after 3 lots of tracking. Just had a single front spring changed at christmas and this also resulted in severe pulling to one side until I got the other side changed. Springs or tyres is could well be. |
craigy_87
aint the tyres but spring/damper might be a good shout |
lotek
Seasoned Pro Location: Berkshire Registered: 04 Dec 2007 Posts: 6,107 Status: Offline |
see if your balljoint pinchbolt is loose. |
lotek wrote: see if your balljoint pinchbolt is loose. but don't over-tighten them! 23lbft off the top of my head. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rikky
wishbone bushes or caliper________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
craigy_87
when they came in to the reception bit to ask if anythin else had been changed recently apart from the track rod ends i told them about wishbones, surely they'd have checked that. i'll double check to be sure |
lotek
welshpug! wrote: lotek wrote: see if your balljoint pinchbolt is loose. but don't over-tighten them! 23lbft off the top of my head. Tell me about it , ive snapped mine about 20mins ago. no car till whenever then new ones turn up! |
craigy_87
rikky wrote: wishbone bushes or caliper just had new P bushes not long ago an the front bush looked in decent condition. so list so far is snapped spring pinch bolt and caliper |
adamski_306
Regular Location: Cambridge Registered: 29 Jul 2008 Posts: 377 Status: Offline |
Mine pulled to the right, it turned out to be the suspension top mount and bearing. |
idboo
Regular Location: Rotherham Registered: 29 Oct 2006 Posts: 264 Status: Offline |
adamski_306 wrote: Mine pulled to the right, it turned out to be the suspension top mount and bearing. Same here, just changed the top mounts on mine, the right bearing was shot, only pulled slightly to the right before but tracks perfect now. |
gilesy
Seasoned Pro Location: Greenwich - in that London Registered: 03 Apr 2006 Posts: 5,133 Status: Offline |
I asked Ash the exact same question yesterday...it was tracked with no one realising it had a random 55 profile OSR. Anyway I replaced the balljoints and it slightly pulled left.I then got some correct 55 profile wheels tyres and it then started pulling right (as you would expect as the radius on the NS tyres was now larger. I have taken it to 3 different Kwik-fit branches and it will take about 8-10 seconds at 70mph to go from one lane to another on a motorway, still to the right. EDIT: My car has new P bushes, balljoints, TRE's, droplinks and discs/pads within last 1000 miles. |
craigy_87
adamski_306 wrote: Mine pulled to the right, it turned out to be the suspension top mount and bearing. hmmmm the guy at the garage did mention something about my top mounts |
chrisd306
Seasoned Pro Location: Perth Scotland Registered: 26 Nov 2005 Posts: 10,061 Status: Offline |
buy my shockies mate and i will get you some bearings for your mounts and be sound, shouldnt be the pinch bolts as i fitted them and they were new mind.________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
adamski_306
gilesy wrote: it will take about 8-10 seconds at 70mph to go from one lane to another on a motorway, still to the right. This is what mine was like, its definatly worth checking your top mounts. |
