Author Subject: Differences between S16 engine & GTi6
jaymz
Hi Guys,
I have a S16 here in Aus and am doing it up as a track car. Im a newbie here so take it easy on me guys.
Info is hard to get over here and short of trolling the internet for hours i thought you guys might be able to help and it may turn into a FAQ as i could not find it.
What are the specific diferences between these two engines?
Thanks for your help,
Jamie
Posted 25th Mar 2010 at 06:57
JWP EFi
Turbo Legend!
quite alot of differences really, gti6 has 10.8:1 compression as opposed to 10.4:1, totally redesigned cylinder head-thinner valve stems (6mm), harmonic inlet manifold which replaces the ACAV setup as on S16, which in my opinion didn't really work that good anyway. Proper 4 branch equal length exhaust manifold (work of art!) Magneti Marelli engine management instead of the Bosch Motronic 3.2. Overall a far better engine in terms of power/torque and setup. Hope this helps. I'm still to own a gti6, going to get myself 1 before summer
Posted 25th Mar 2010 at 23:16
tarret
hi mate
The S16 was replaced with the more powerful GTI-6 in 1996. It had more power courtesy of a reworked engine, a close-ratio 6-speed gearbox and some subtle chassis revisions.The GTI-6 engine was more flexible than that in the S16, and the new gearbox made it easier to use the engine more effectively
first the s16,
155 bhp,
142 ft-lb,
0-60 not to sure about (8.00),
top speed 130mph,
5 speed gearbox,
about 1300kg,
has lighter aluminum head (about 20kg),
The XU10J4Z (s16)also shares many design features with the legendary T16 engine.
the gti 6,
167 bhp,
145 ft-lb,
0-60 (7.90)
quarter mile (16.40)
top speed about 130mph
6 speed gearbox,
about 1214kg,
Bore
Posted 25th Mar 2010 at 23:40
JWP EFi
Turbo Legend!
plus what tarret wrote!!
Posted 26th Mar 2010 at 00:37
JWP EFi
Turbo Legend!
both S16 and GTi6 have aluminium heads as do all peugeot engines, i think what tarret ment to say was the block is aluminium and 20kg lighter, but this only applies to the XU9J4 Mi16 (1905cc) engine, the later phase 2 405 Mi16's were fitted with the same engine as the 306 S16. all XU10's are iron blocks
Posted 26th Mar 2010 at 00:43
same block and crank, different pistons+rods and head.
plus everything bolted to them.
chassis is the same, suspension nearly exactly the same.
front brakes larger on the gti6.
more gears but shit r/h steering long on the gti6/rallye.
completely different intake and exhaust manifolds, different downpipes.
similar centre and rear exhaust boxes.
S16 weighs less than a Rallye which weighs around the same as a P1 gti6, P2-3 gti6 is a fat bas**rd.
Posted 26th Mar 2010 at 00:55
allesclar
top speed of a six is 140 i though? managed it in stock gti-6 before so...
Team allesclar ®
ballys16
tarret wrote:
hi mate
first the s16,
155 bhp,
142 ft-lb,
top speed 130mph,
5 speed gearbox,
about 1300kg,
the gti 6,
167 bhp,
145 ft-lb,
0-60 (7.90)
6 speed gearbox,
about 1214kg,
Bore
XSi 8V -> S16
Posted 26th Mar 2010 at 01:17
jaymz
Ok guys which is it, same or different blockHuh?
Dont tell me my S16 has a dirty cast iron counter weight upfront!
My car weighed 1230kg with half tank & full interior, now weighs 1100 with one seat and very little interior Razz
Will pull the dash & door skins tomorrow & toss all the A/C also.
Just out of interest, has anyone swapped in the motor from a 206 GTi RC?
Posted 26th Mar 2010 at 13:26
s16 is iron block
Posted 26th Mar 2010 at 13:39
not into a 306 that I know of, but into a 205 yes, of what I've seen of them they are lovely torquey motors, especially when mapped properly, they are used in the S200 207's with great results albeit quite different to a road engine !
trouble with them is the multiplexing so they will need an aftermarket ecu straight up to run in a 306, not difficult, but it is added expense.
If you're on aussiefrogs have a look for Magic's posts about mapping a Haltech piggyback on one of these, quite astonishing torque increases on a stock motor.
Posted 26th Mar 2010 at 15:29
oldbrownshoe
theres more oil jets for the crank in the S16.
the parts quality in the S16 (and MI16) are better.
the two engine are heavy, the MI16 weights 132 kg.
if i had the choice i would go for the 2.2 l 407,
it's advanced all aluminum engine.
French military victories?
Did you mean French military defeats?
Posted 26th Mar 2010 at 15:44
