Author Subject: Smoke
webster
Got some smoke coming out of exhaust, white, filled it with 10 litres of oil nby mistake before and its also been sat for a while, its now running right amount of fresh oil new filters etc but when I started it other day after its been sat for ages it was pretty smokey (its in a workshop)
Is this normal because it's been sat?
Whats best? leave it running a while and check it stops?
Thanks
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 27th Mar 2010 at 03:29
allesclar
hey matey, when i filled my engine up with too much oil, it smoked white. have you fully drained the engine and only put in 5 litres of oil?
could be that you just need to take it out to get it through the system, although i have just had to have my coolant pipes at the back of the engine replaced because of oil contamination, when i over filled the engine with oil last may Sad
10 litres is shit loads, i would also check the manifold that there is no oil there, as i noticed there was abit of oil from last time in the induction piping i had.
Team allesclar ®
Posted 27th Mar 2010 at 03:33
it'll probably smoke for a while as its soaked the exhaust too.
Posted 27th Mar 2010 at 03:39
webster
ok to run it like that tho ye?
Also what triggers the fuel cut off ? red button thing under bonnet..
And one last question, the oil cooler, has two pipes, I have connected one (cant remember which) - where are the two meant to go to?
Sorry for the novice questions Smile
Posted 27th Mar 2010 at 03:42
webster
Going to be finishing it off tommorow - if anyone has a number I can take to call if I have any questions it would be much appreciated..
Posted 27th Mar 2010 at 03:46
allesclar
as in a mocal oil cooler?
one in the left side of the oil themal place, and one in the other side.
Team allesclar ®
Posted 27th Mar 2010 at 03:48
allesclar
i think you mean this?
Team allesclar ®
Posted 27th Mar 2010 at 03:50
webster
yeah but where do they connect to Razz
pm me your number again bro have chaNGED PHONES, my questions will be real basic but cause i cant see one setup to copy i want to be sure :p
Posted 27th Mar 2010 at 04:35
allesclar
straight to the oil cooler Smile what have you mounted the oil cooler rad?
i will text you my number bud.
Team allesclar ®
Posted 27th Mar 2010 at 04:42
webster
Posted 27th Mar 2010 at 06:12
webster
oil cooler rad?
I have mounted the front rad
Posted 27th Mar 2010 at 06:14
allesclar
did you not get my text? i would hide the number if i were you Wink
Team allesclar ®
allesclar
ok, you dont meant coolant by anychance? the front rad?
do you have a kit like this?
Team allesclar ®
Posted 27th Mar 2010 at 06:17
