Author Subject: loosing coolant
cayuse
My gti6 has been loosing coolant all day, i noticed it had all gone so i filled it back up and drove about for a bit and its empty again. Temp gauge sits on about 90-100 degrees when driving.
Thing is when i filled it back up it only took about a litre which didn't seem much.
Any ideas?
Posted 27th Mar 2010 at 23:30
yeah, its leaking somewhere!
Posted 27th Mar 2010 at 23:32
cayuse
But it isnt comming out when i fill it back up!
Posted 27th Mar 2010 at 23:33
it must be somewhere otherwise the level wouldn't drop....
Posted 27th Mar 2010 at 23:36
davidmartin
check the draining plug at the bottom of the rad,mine came loose just last week ,luckilly it was parked up outside the house when a boy up the road knocked on the door to tell me there was a big puddle under my car.
pet hate, the cat
Posted 27th Mar 2010 at 23:41
cayuse
is that on the bottom left? I can't see any leaks and there is no puddles!
Posted 27th Mar 2010 at 23:46
davidmartin
Passenger side,mine was dripping like a good one,burned my arm with the "have I bled it properly" paranoia too.
pet hate, the cat
Posted 27th Mar 2010 at 23:53
cayuse
i read not all radiators have a draining plug, I think mine is standard as it looks old but i cant see anything on the passenger side!
Posted 27th Mar 2010 at 23:55
what does it start like after being left overnight?
Posted 28th Mar 2010 at 00:05
cayuse
not sure only happened today. My cooling fans have to be swited on manually (previous owner put a manual overide in) and i forgot today. I parked up and i noticed some coolant from under where the over flow pipe is then when driving home i noticed it was running hot then checked and all the water had gone so i can only think that i let it over heat but i can't be 100%.
Posted 28th Mar 2010 at 00:12
