displaying posts 1 to 2 of 2
Author Subject: Cambelt tension
mabgti
NV motors
Does anyone here have a rough guide to how much tension should be on the 136 kit? is there a set position for the tensioner/marking?
Reason being i get alot of belt movement on/off throttle so am a bit unsure what its suppose to be like?? any vidS?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 5th Apr 2010 at 22:34
jeffers Forum Admin
Mabz, on the long side of the belt ie the side opposite the tensioner, between the cam pulley and the idler, you should be able to twist the belt about 45- 90 degrees max iirc.
Team Running Engine again!
Team Negative Camber!
Posted 6th Apr 2010 at 13:01
