Author Subject: Running temps..
strugs
Hi folks.. on the move, my temp gauge hardly moves off 70. It climbs in traffic (and, as I discovered the other day, the cooling fans aren't working - seperate post for that; think they're just 'sticky'!!), but settles back at 70-75 once moving again.. What should the temp be on the move? Cheers! Smile
2000/W 306 GTi-6, Moonstone money-pit!!
Posted 7th Apr 2010 at 02:12
phil19gti
Mine sits at about 75, rises in traffic but as soon as I get movement again rests back at 75.
There's loads of topics on this using the search button (top right).
2006 Performance Blue Mondeo ST TDCI
1999 Black 306 Rallye
1991 Lazer Green 205 1.9 GTi
2003 Blue Focus RS
1999 White 306 Rallye
1992 Red 205 1.9 GTi
1988 Red 205 1.6 GTi
Posted 7th Apr 2010 at 02:16
mine used to sit at 83 odd degrees all the time (when it held water that is)
I'd fit a new thermostat, might be stuck open.
Posted 7th Apr 2010 at 02:17
lwgti-6
Water, constantly 72 - 75ish when driving sensible.
Oil, sits under 90 deg also when driving sensibly.
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 7th Apr 2010 at 02:24
strugs
Cheers chap. Did search on 'running temperature' and came up with nothing, but 'running temp' came up with a few! I love forum search engines.. LOL
Posted 7th Apr 2010 at 02:25
Sounds like the thermostat is stuck open to me fella....Yes
Stan.
Posted 7th Apr 2010 at 02:26
strugs
Thanks for the responses folks - sounds pretty normal then (assuming it wouldn't climb at all if the thermostat was stuck?).. Smile Just need to get the fans working at get on with enjoying the car!!
Posted 7th Apr 2010 at 02:28
strugs
Stan.
Woudl the gauge not climb at all if the 'stat was dodgy? Unsure
Posted 7th Apr 2010 at 02:29
justinaccurate
I agree with Stan. Stuck thermostat will sit at 70 in normal driving conditions and rise when in traffic, shouldnt go over the usual 97 tho as thats when fans kick in to cool down the water.
Thermostats are designed to cut in at 82, regardless of whether you have an aluminium rad
Posted 7th Apr 2010 at 02:36
strugs
B@lls.. Sad More money to spend on the flipping thing then.. Angry
Posted 7th Apr 2010 at 02:40
justinaccurate
Not that bad to be honest. I'd say fans were more of a priority, overheat = almost certain HG failure
A lot of people seem to have cars that run at 70 and general opinion is its not overly damaging to the car.
Plus its quite cheap and easy to replace the thermostat - wont need to drain coolant if you are quick and don't mind a bit of spillage Wink
Posted 7th Apr 2010 at 04:21
spike_uk06
Just under 80 here in normal driving.
Team China
Team Pirelli
Team Cracked Bumper
92k
20th Nov 1999 she was born
Posted 7th Apr 2010 at 05:28
strugs
Yep, fans defo the priority! Wish me luck..
Posted 8th Apr 2010 at 04:15
