Author Subject: will RFK fit ?
oldbrownshoe
I'v got opportunity to buy 2007 low millage from 206RC , besides the legal issue , what technical issues i need to sort out ?
will it fit the mounts ?
French military victories?
Did you mean French military defeats?
Posted 9th Apr 2010 at 17:50
Rich E Forum Admin
It would be easier into an XU shell but you'll have to do some DIY with the mounts on either.
The biggest problem will be the management. You'll need to use aftermarket management as the multiplexed ECU is near impossible to get running without the rest of the BSI system.
Posted 9th Apr 2010 at 17:57
doubt it very much. most things need an element of fabrication, i dont even know what engine code it is but i bet it wont fit anywhere nearly as easy as it looks/sounds
Rich E Forum Admin
It's the EW10J4S from the 206 GTi 180 / 307 CC 180.
The 206 180 was sold as the RC everywhere else.
Posted 9th Apr 2010 at 17:59
oldbrownshoe
Reading this :
"206GTi138 engine into a 205. But the enginemounts are the same on 205 and 405. And the enginemounts on the 138 and 180 are also identical. We had the problem of the engine sitting not straight as well and modified the upper enginemount."
http://forum.405mi16.com/lofiversion/index.php/t20.html
is the ZX16V Mounting the same as the 205 / 405 ?
Posted 18th Apr 2010 at 13:41
Wouldn't be worried about mounting it as that can be overcome, the electrics are your biggest problem by far.
Posted 18th Apr 2010 at 18:56
oldbrownshoe
the electrics can be sort out using after market management like DTAfast or mega squirt 3 .
no one know if the ZX16V/306S16 Mounting is the same as the 205 / 405 ?
Posted 18th Apr 2010 at 22:48
Rich E Forum Admin
Depends what models of 205 and 405. The upper mounts should be the same on all XU engined cars.
Posted 19th Apr 2010 at 00:25
yes it will be exactly the same points as a 205, so all the solutions found there apply here.
Posted 19th Apr 2010 at 16:46
oldbrownshoe
more issues : i'v been told that i need also the BE4 gearbox as well Dry , the RFK sits in 15deg
angle while the XU stretch it's bottom into 30 deg
the BE3 won't cope with that.
Posted 21st Apr 2010 at 14:22
BE4 fitment is easy, just use original 306 driveshafts, straight in.
fit 306 lever arms to gearbox if needed, unsure if they are.
Posted 21st Apr 2010 at 15:30
oldbrownshoe
what you mean by "original 306 driveshafts"
isn't the ZX16V driveshafts identical ?
what is lever arm ?
i'm a bit confused, i'v talked with a friend
who claim that i could use the original ECU
after he will crack the immobilizer
then other guy told me that it won't help since
i'll have to rewire also the dashboard and every electric component to the ECU with the multiplex .
Posted 21st Apr 2010 at 16:31
oldbrownshoe
i have an offer for engine from C AND R AUTOSALVAGE
from BIRMINGHAM , the rate is too high for me now,
and i don't feel good when being pushed.
is someone know this business well enough to recommend it ?
Posted 26th May 2010 at 21:39
